Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
NAME
v.select - Selects features from vector map (A) by features from other vector map (B).
KEYWORDS
vector, spatial query
SYNOPSIS
v.select
v.select help
v.select [-tcr] ainput=name [atype=string[,string,...]] [alayer=integer] binput=name [btype=string[,string,...]] [blayer=integer] output=name [operator=string] [--overwrite] [--verbose] [--quiet]
Flags:
- -t
- Do not create attribute table
- -c
- Do not skip features without category
- -r
- Reverse selection
- --overwrite
- Allow output files to overwrite existing files
- --verbose
- Verbose module output
- --quiet
- Quiet module output
Parameters:
- ainput=name
- Name of input vector map (A)
- atype=string[,string,...]
- Feature type (vector map A)
- Feature type
- Options: point,line,boundary,centroid,area
- Default: point,line,boundary,centroid,area
- alayer=integer
- Layer number (vector map A)
- A single vector map can be connected to multiple database tables. This number determines which table to use.
- Default: 1
- binput=name
- Name of input vector map (B)
- btype=string[,string,...]
- Feature type (vector map B)
- Feature type
- blayer=integer
- Layer number (vector map B)
- Default: 1
- output=name
- Name for output vector map
- operator=string
- Operator defines required relation between features
- A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.
- Options: overlap
- Default: overlap
- overlap: features partially or completely overlap
DESCRIPTION
v.select allows the user to select features from a vector
map by features from another one.
Supported operators (without GEOS):
- overlap - features partially or completely overlap
Supported operators (with GEOS):
- equals - features are spatially equals
- disjoint - features do not spatially intersect
- intersects - features spatially intersect
- touches - features spatially touches
- crosses - features spatially crosses
- within - feature A is completely inside feature B
- contains - feature B is completely inside feature A
- overlaps - features spatially overlap
- relate - feature A is spatially related to feature B
NOTES
Only features with category numbers will be considered. If required
the v.category module can be
used to add them. Typically boundaries do not need to be given a
category number, as an area's attributes are inherited from the
centroid. Typically points, lines, and centroids will always want to
have a cat number. E.g. take a road which separates two farms. It is
ambiguous as to which farm an attribute that is attached to the road
belongs to. The boundary only needs a cat number if it will hold its
own attributes, such as road name or pavement form. A centroid in each
paddock holds the information with respect to ownership, area, etc.
EXAMPLES
Extract fire stations (points) from urban area map (polygon) - North Carolina
data set:
v.select ainput=firestations binput=urbanarea output=urban_firestations \
operator=overlap
Extract Italian rivers from VMAP0 watercourses map:
v.select ainput=watrcrsl_eurnasia_wgs84 binput=italy_area \
output=watrcrsl_italy operator=overlap
TODO
Processing areas with GEOS is currently incredibly slow. Significant
speed-up is required.
SEE ALSO
v.category,
v.overlay,
v.extract
GRASS SQL interface
AUTHORS
Radim Blazek
GEOS support by Martin Landa, Czech Technical University in Prague, Czech Republic
Last changed: $Date: 2012-12-10 02:28:57 -0800 (Mon, 10 Dec 2012) $
Main index - vector index - Full index
© 2003-2014 GRASS Development Team
