GRASS logo
Note: A new GRASS GIS stable version has been released: GRASS GIS 7.4, available here.
Updated manual page: here
PostgreSQL DATABASE DRIVER
Table of contents
PostgreSQL database driver enables GRASS to store vector attributes in PostgreSQL server.
Creating a PostgreSQL database
A new database is created with createdb, see the PostgreSQL manual for details.
Connecting GRASS to PostgreSQL
# example for connecting to a PostgreSQL server:
db.connect driver=pg database=mydb
db.login user=myname pass=secret host=myserver.osgeo.org
db.connect -p
db.tables -p
Supported SQL commands
All SQL commands supported by PostgreSQL. It's not possible to use C-like escapes (with backslash like \n etc) within the SQL syntax.
Operators available in conditions
All SQL operators supported by PostgreSQL.
Adding an unique ID column
Import vector module require an unique ID column which can be generated as follows in a PostgreSQL table:
db.execute sql="ALTER TABLE mytable ADD ID integer"
db.execute sql="CREATE SEQUENCE mytable_seq"
db.execute sql="UPDATE mytable SET ID = nextval('mytable_seq')"
db.execute sql="DROP SEQUENCE mytable_seq"
Attribute import into PostgreSQL
CSV import into PostgreSQL:
\h copy
COPY t1 FROM 'filename' USING DELIMITERS ',';
Geometry import from PostgreSQL table into GRASS
v.in.db creates a new vector (points) map from a database table containing coordinates. See here for examples.
PostGIS: PostgreSQL with vector geometry
PostGIS: adds geographic object support to PostgreSQL.
Example: Import from PostGIS
In an existing PostGIS database, create the following table:
CREATE TABLE test
 id serial NOT NULL,
 mytime timestamp DEFAULT now(),
 text varchar,
 wkb_geometry geometry,
 CONSTRAINT test_pkey PRIMARY KEY (id)
) WITHOUT OIDS;
# insert value
INSERT INTO test (text, wkb_geometry)
 VALUES ('Name',geometryFromText('POLYGON((600000 200000,650000
 200000,650000 250000,600000 250000,600000 200000))',-1));
# register geometry column
select AddGeometryColumn ('postgis', 'test', 'geometry', -1, 'GEOMETRY', 2);
GRASS can import this PostGIS polygon map as follows:
v.in.ogr input="PG:host=localhost dbname=postgis user=neteler" layer=test \
         output=test type=boundary,centroid
v.db.select test
v.info -t test
Geometry Converters
SEE ALSO
db.connect, db.execute
Database management in GRASS GIS
Help pages for database modules
SQL support in GRASS GIS
REFERENCES
Last changed: $Date: 2017-01-17 11:28:47 -0800 (Tue, 17 Jan 2017) $
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2018 GRASS Development Team, GRASS GIS 7.2.4svn Reference Manual
