Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
d.erase | Erases the contents of the active graphics display frame with user defined color. |
d.frame | Manages display frames on the user's graphics monitor. |
d.his | Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers. |
d.info | Displays information about the active display monitor. |
d.mon | Controls graphics display monitors from the command line. |
d.rast | Displays user-specified raster map in the active graphics frame. |
d.redraw | Redraws the content of currently selected monitor. |
d.rgb | Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame. |
d.vect | Displays user-specified vector map in the active graphics frame. |
m.nviz.script | Creates fly-through script to run in NVIZ. |
wxpyimgview | Views BMP images from the PNG driver. |
ximgview | View BMP images from the PNG driver. |
See also the corresponding keyword graphics for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 7.8.9dev Reference Manual
