Compiling on MacOSX
From GRASS-Wiki
Jump to: navigation, search
Up-to-date compilation instructions are maintained in the source macosx/ReadMe.rtf. This builds a double-clickable application with "aqua" options where possible (Tcl/Tk, Python, OpenGL,...) and leaves out obscure X11-only-based features that have newer system-agnostic options (like motif/xganim), though these newer features may not be quite as fully-featured, yet. The X11 display system is included, since it is simple to include and is still quite useful.
The method below is for the older X11-based compilation, and includes the X11 motif-based xganim.
To build Grass from source you can use the frameworks that are on : http://www.kyngchaos.com/software:frameworks great thanks to W.Kyngesburye.
After installing all the frameworks you can add some library such "motif" needed by Xganim, using fink or build the source code
Install from source the tcl-tk library : http://www.tcl.tk/software/tcltk/downloadnow84.tml in /usr/local
Postgres can be easily compiled from source.
Download a SVN version http://grass.osgeo.org/download/index.php
Then configure and make GRASS from SVN/source code snapshot :
cd /path_to_grass_source
./configure --enable-sysv --with-x --with-opengl=x11 --without-odbc --with-cxx --with-freetype \
--with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include \
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
--with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.5/Programs/gdal-config \
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
--with-proj-share=/Library/Frameworks/PROJ.framework/Versions/4.5/unix/share/ \
--with-tiff --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
--with-fftw --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include \
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib \
--with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib \
--with-freetype --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include \
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-python --with-readline \
--with-readline-includes=/sw/include/readline --with-readline-libs=/sw/lib --with-tcltk-includes=/usr/local/include \
--with-tcltk-libs=/usr/local/lib --with-blas --with-lapack \
--with-blas-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers \
--with-lapack-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers \
--with-motif --with-motif-includes=/sw/include --with-motif-libs=/sw/lib --with-glw
make
sudo make install
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
In other languages
