Convert points to lines
From GRASS-Wiki
Jump to: navigation, search
Q: Is there a way to construct a vector line(s) map connecting selected points?
A: There are two possibilities:
Converting points map into lines map
You can use v.in.lines for that. The input can be generated with v.out.ascii.
Spearfish example:
  v.out.ascii archsites fs=, where="cat=1 or cat= 3"
  593493,4914730,1
  589860,4922000,3
  # so:
  v.out.ascii archsites fs=, where="cat=1 or cat= 3" | cut -d',' -f1,2 | \
      v.in.lines in=- out=myline fs=,
  v.category in=myline out=line_with_cat option=add
Converting CSV points file into lines map
Suppose you have a CSV file "mypoints.csv" containing three point-pairs to be connected (start point coordinates, end point coordinates):
 east1,north1,east2,north2
 593493,4914730,589860,4922000
 590400,4922820,593549,4925500
 600375,4925235,606635,4920773
We can convert these three point pairs into three lines:
  cat mypoints.csv | grep -v "north1" | awk -F',' '{printf "%f,%f\n%f,%f\nNaN,NaN\n",$1, $2 ,$3 ,$4}' > mypoints_formatted.csv
  v.in.lines in=mypoints_formatted.csv out=mylines fs=,
  v.category in=mylines out=lines_with_cat option=add
See also
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
