GRASS Debugging
From GRASS-Wiki
Jump to: navigation, search
The following hints assume to work on a working-copy of the GRASS CVS directory.
Additionally it is good to have set the debbugging symbols during compile-time. Do not strip the libraries or use optimization in the compile. see INSTALL and doc/debugging.txt in the source code for more information.
Contents
Setting GRASS-environment variables (numbers: 1-5)
g.gisenv set="DEBUG=1"
  • A higher debug level means you see more messages.
  • These messages are always present regardless of compiler settings.
  • A setting of "5" is the most verbose, "0" is no debug messages.
Common problems
  • Check that the region settings are not totally overwhelming for the raster engine. While there is no set upper limit, anything bigger than 20000x20000 is considered large, and anything an order of mangnitude bigger than that will most likely end with out of memory or large file problems, especially on 32-bit platforms built without LFS support. Many modules will continue to work on these huge datasets, but processing time may make it not worth the while.
g.region -p
Watching top
top is a nice command line utility for watching a process's progression. While it won't give you many hard metrics it will give you an idea of what is happening. To make the view a little more stable, with top running from the command line press "M" to sort by memory usage.
Using GDB
The GNU Debugger may be used to diagnose Segmentation Faults and other weirdness.
Compile Time Setup
To add debugging information into the built binary, add -g to the CFLAGS arguments.
Do not use -O for optimization and do not strip the binaries with LDFLAGS="-s".
Using gdb on command line
  • Running a program inside GDB works (installation of GDB required :-)
(e.g. on Debian GNU/Linux: apt-get install gdb)
  • Use the exact module name on the command line (at the GRASS prompt) without arguments. Put any command line arguments on the (gdb) command line after the word run.
 gdb `which v.in.ogr`
 run "out=some_map dsn="PG:dbname=postgis user=me" olayer=postgislayer"
  • when it crashes, type "bt full" for a full backtrace
  • type "l" to list where in the source code it got to
  • type "frame 2" to switch to the second level function (see the backtrace), there you can again type "l" to see where it got up to.
or you can optionally add arguments to gdb directly on the commandline:
 gdb --args v.in.ogr out=bla dsn="PG:dbname=postgis user=me" olayer=postgislayer
  • Attaching to child process:
use "attach <pid>" to attach to an existing process (needed for DBMI debugging etc).
For details, see this hint
Using gdb with a mixed C/TclTK application
You can't invoke gdb directly on "nviz" or $GISBASE/bin/nviz, as that is a shell script. But it's a trivial script which essentially just does:
$GISBASE/etc/nviz2.2/nviz -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script ${1+"$@"}
You can debug the $GISBASE/etc/nviz2.2/nviz binary as with any other program, i.e.:
$ gdb $GISBASE/etc/nviz2.2/nviz
> run -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script <any args>
Or, if you don't need to debug the startup, you can start NVIZ then "attach" to the process, as follows:
Once NVIZ is running, get its PID, then:
> attach <pid>
> break Create_OS_Ctx
> cont
Selecting the menu option will re-enter the debugger. Single-step through the function (with "next"), printing out the values of any variables as they are assigned.
Using gdb within GNU Emacs
emacs general/manage/cmd/remove.c
  • create second buffer by C-x 2
  • move cursor to the second buffer by C-x o, then M-x gdb, Enter
  • type module name which you would like to debug, e.g. g.remove, Enter
  • now you can use gdb inside GNU Emacs
Using DDD (gdb graphical frontend)
  • running a program inside DDD works (installation of ddd and gdb required :-), (on Debian GNU/Linux: apt-get install gdb ddd)
ddd `which v.in.ogr`
http://mpa.itc.it/markus/grass61/debugging/crash_1_small.jpg
  • Run (from main menu PROGRAM): "out=bla dsn="PG:dbname=postgis user=me" olayer=postgislayer"
http://mpa.itc.it/markus/grass61/debugging/ddd_1_small.jpg
  • run with parameters
  • when it crashes, use the UP menu item to trace back
http://mpa.itc.it/markus/grass61/debugging/ddd_2_going_up_small.jpg
  • reach the line where it crashed
  • set a breakpoint, then run again to stop before the crash
http://mpa.itc.it/markus/grass61/debugging/ddd_3_breakpoint_small.jpg
  • right mouse button on variables permits to display them etc.
http://mpa.itc.it/markus/grass61/debugging/ddd_4_displ_vars_small.jpg
  • figure out why it crashed there. This requires PATIENCE. But you will nearly save the world if you identify the problem :-)
Using kdbg (gdb graphical frontend)
  • kdbg is not unlike DDD, but it's a KDE application.
  • Use is similar to DDD.
  • Start with (within GRASS):
kdbg `which g.module`
  • Fill in command line arguments with menu item Execution->Arguments.
  • Open the View->Locals window.
  • Click the Run icon (or Execution->Run) and see where it breaks.
  • Set pause-points by clicking a red stop-sign to the left of the "+" on a line of the source code. From there you can step through instructions.
  • Explore the values of variables in the locals window.
Using ldd
ldd will show the shared library dependencies for a program or library. For example:
For a module:
GRASS> ldd `which v.in.ogr`
For a library:
$ ldd /usr/src/grass/grass-6.2.2/dist.i686-pc-linux-gnu/lib/libgrass_gis.so
The output looks like this:
       libz.so.1 => /usr/lib/libz.so.1 (0x40077000)
       libgrass_datetime.so => not found
       libc.so.6 => /lib/libc.so.6 (0x4008a000)
       /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
In the above example libgrass_datetime.so is missing causing an Illegal Instruction error in libgis. A common error occurs when there are more than one versions of a support library installed, and the GRASS build is using the wrong one. ldd is good for spotting this.
Library search path
If a support library like libgdal can't be found, and you are sure it is installed, make sure the library search path is set correctly. For example in Linux if GDAL was installed to /usr/local, add the line "/usr/local/lib" to the /etc/ld.so.conf file, and as root run ldconfig to rebuild the library links and cache.
Alternatively you can add the library path to the $LD_LIBRARY_PATH environmental variable.
Using nm
nm will show a list symbols contained in a library or a program. Use this if you want to check which functions it calls.
For example:
GRASS> nm $GISBASE/lib/libgrass_gis.so
GRASS> nm `which r.digit`
  • see also the tools/sql.sh script in the GRASS souce code, which will run "nm" on every object file, library and executable to find dependencies. The result is stored in a PostgreSQL database.
Using strace
  • running the command through strace could give you another hint what is going wrong somewhere.
For example:
strace v.in.ogr out=your_map dsn="PG:dbname=postgis user=me" olayer=postgislayer
Using Valgrind
  • Valgrind is a tool to check for memory leaks
(Insert howto here)
Examples:
  • analysis of heap usage
CMD="v.in.ascii -zt z=3 in=lidaratm2_250k.txt out=lidaratm2_250k fs=,"
valgrind --tool=massif --format=html  $CMD --o
  • analysis of memory leaks
Quick addrcheck tool
valgrind -v --tool=addrcheck --leak-check=yes  $CMD
Full memcheck tool, including non-orphaned, but left over, allocated memory
valgrind --tool=memcheck --leak-check=yes --show-reachable=yes  $CMD --o
  • Valgrind can create PostScript output charts. To convert PostScript to PNG:
('pstoimg' is part of the latex2html Debian package)
pstoimg -aaliastext -flip r90 -out massif.550.png -scale 1.3 -crop a massif.550.ps
Using Electric Fence
  • Electric Fence checks for bad memory writes, ie specific malloc() over-runs and under-runs.
(Insert howto here)
Example:
CMD="gdalwarp -tps -srcnodata 255 -dstnodata 255 \
       -of GTiff -rcs ${TMP}.tif ${OUTFILE}_warp"
LD_PRELOAD=libefence.so.0.0 $CMD
Using a profiling tool
A profiling tool may be used to identify the bottlenecks in long running processes.
Kcachegrind
kcachegrind is a visualization tool for Valgrind's callgrind profiling tool (formerly known as the calltree skin). It is very simple to use. Install the GraphViz package as well.
Example:
# Spearfish dataset
g.region rast=elevation.dem
v.random n=10000 out=rand10k
v.db.addtable rand10k column="elev INT"
CMD="v.what.rast rand10k rast=elevation.dem column=elev"
valgrind --tool=callgrind --trace-children=yes $CMD
This creates a file containing profiling information which kcachegrind can load. We include --trace-children in the above example so we can profile the DBF driver process as well as the main v.what.rast process.
kcachegrind callgrind.out.12345
In the above example from the two process costs we can see that 99.5% is taken by the dbf process and 0.5% is taken by the v.what.rast process. Within the dbf process almost 50% is taken by G_debug() and G_strcasecmp().
gprof
(Insert howto here)
Using Mudflap
GCC built in feature, that "instruments all risky pointer/array dereferencing operations, some standard library string/heap functions, and some other associated constructs with range/validity tests. Modules so instrumented should be immune to buffer overflows, invalid heap use, and some other classes of C/C++ programming errors. The instrumentation relies on a separate runtime library (libmudflap), which will be linked into a program if -fmudflap -lmudflap is given at link time." GCC Wiki
  • Requires GCC with mudflap support (GCC 4.x with mudflap USE flag on Gentoo, separate library "libmudflap*" in other distros);
  • Add -fmudflap and -lmudflap options (Is this correct way? It works...):
    • in include/Make/Platform.make add -lmudflap to LD_SEARCH_FLAGS;
    • in include/Make/Platform.make add -fmudflap to CFLAGS1;
  • Disable mudflap during compilation
export MUDFLAP_OPTIONS='-mode-nop -viol-nop'
  • Compile GRASS (make clean && make). For best results use NO optimisations for compilation (-O0);
  • Use GRASS.
    • To disable warnings
    • To enable warnings
export MUDFLAP_OPTIONS='-mode-check -viol-nop -check-initialization'
More information about debugging with mudflap, can be found here.
Skimming the ChangeLog for changes
  • use the tool svn2cl.sh for generating a local changelog-file
Patches
  • For instructions on creating and applying patches the see Patches wiki page.
Personal tools
