GRASS Location Wizard
From GRASS-Wiki
Jump to: navigation, search
Creating a new location in GRASS
The location wizard enables to create a new location in a few simple steps. It provides a number of ways to set the map projection: from a geodata file (SHAPE, GeoTIFF etc), using an EPSG code, settting parameters manually, etc.
Here an example:
First screen of the Location wizard which is found in the GRASS GIS Startup window:
GRASS Location Wizard: user choices
The location wizard also helps you select the appropriate geodetic datum and transform parameters for your map projection.:
GRASS Location Wizard: choosing the projection
GRASS Location Wizard: choosing the geodetic datum
GRASS Location Wizard: finishing the creation of the new location
You are then brought back to the initial window of GRASS and enter the session with the "Start GRASS" button.
Import raster data
From the main GRASS GIS menu, go to "File" --> "Import raster data" for easy raster map import.
For example, to import multiple GeoTIFF files, run:
Bulk import of GeoTIFF via menu
Bulk import of GeoTIFF via menu (files are auto-selected)
Import vector data
From the main GRASS GIS menu, go to "File" --> "Import vector data" for easy vector map import.
The usage is similar to that of raster data (see above).
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
