GRASS and Java
From GRASS-Wiki
Jump to: navigation, search
Contents
vtk-grass-bridge with JAVA bindings
The vtk-grass-bridge main page http://code.google.com/p/vtk-grass-bridge/
Short introduction how to compile the vtk-grass-bridge: http://code.google.com/p/vtk-grass-bridge/wiki/HowToCompile
Examples
The Java module v_sample_rast: http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Modules/Java/v_sample_rast.java
Calling GRASS from JAVA
Define:
       public String run(String[] cmd)  {
                       Process p1=rt.exec(cmd, env);
and use:
       gm.run({"r.info", "map=roads"});
Examples
Installation
It seems that calling grass in JAVA by using java.Lang.Runtime.exec() can be implemented easily in Linux platform (tested successfully on Ubuntu 9.10).
First install the grass use the apt-get:
 sudo apt-get install grass  # it will install the latest stable version
After the installation completed you can:
 #Test it in the terminal without JAVA (make sure that you have a GRASS database installed):
Open a terminal and enter:
 grass64
The following the instruction in the screen or check here.
Test the environment settings
Test using GRASS command directly in the terminal:
Set the environment (we assume GRASS being installed under /usr/lib/grass64):
export GISBASE=/usr/lib/grass64
export GISRC=/home/kk/gisrc
export LD_LIBRARY_PATH=$GISBASE/lib
export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
Then try some GRASS command directly, for example:
g.version
g.gisenv
Now call GRASS in JAVA if the above test 2 passed.
Just use the Runtime.getRuntime.exec(String cmd,String[] env):
String cmd="g.version";
String[] exe = { "bash", "-c", cmd };
String[] env={"GISBASE=..","GISRC="".......};  // the environment variables which you set in the step 2.
p=Runtime.getRuntime.exec(exe,env);
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
