Tips and Tricks
From GRASS-Wiki
Jump to: navigation, search
Contents
Tips and Tricks
Using QGIS as a frontend to GRASS
  • QGIS started as a simple viewer for geodata. And that's really what it still is: a simple-to-use geodata viewer with some editing capabilities. That's what it was designed to be and that's what it can do really well. QGIS does not have built-in capabilities for geodata processing and analysis.
However, a while back, Radim Blazek, who was then a core developer of the GRASS 6 system, decided to write a plugin for QGIS that would make it possible to access GRASS functionality from within the QGIS GUI.
And that's what you get today, when you download a binary version of QGIS for your platform: QGIS + GRASS 6 plus a plugin that makes using GRASS from QGIS simple and fun.
QGIS can run as a frontend to GRASS. There is support for displaying maps, editing maps, and execution of simple GIS functions. The GDAL/OGR library is a requirement for that (but for GRASS anyway):
Here is a nice tutorial for editing vectors using QGIS as a frontend to GRASS: Editing_GRASS_vectors_with_QGIS (where did it go? unported from old wiki site? )
To use GDAL and GRASS together, the GDAL-GRASS plugin must be installed:
Test that the GDAL-GRASS plugin is available with this command:
  gdalinfo --formats
Look for a line like "GRASS (ro): GRASS Database Rasters (5.7+)"
Enable the QGIS GRASS plugin from QGIS:
  GUI: Plugins / Plugin Manager / Check the GRASS checkbox
The GRASS toolbar should now be visible. While not a firm requirement, it is easier to start QGIS from within a GRASS session.
Importing SRTM30plus data
See Global datasets page
GMT (The Generic Mapping Tools)
GMT (Generic Mapping Tools) is a Free software package for creating publication quality cartography.
GMT homepage: http://gmt.soest.hawaii.edu
Interfacing R-Statistics with GRASS
GRASS may be combined with R-Statistics to create a very powerful geostatistical analysis platform.
R-Statistics homepage http://www.r-project.org
Using GRASS with an on-line Web-GIS
see:
(please expand)
Starting and running GRASS from a script
See GRASS and Shell.
Running GRASS remotely on OS X
Tiger (OS 10.4) changed the default configuration of SSH from previous versions of OS X. You can no longer start an ssh session with the -X flag and display the Tcl/Tk components of the GRASS GUI remotely. If you are running grass on OS X (10.4) between hosts on a network (i.e. running it on one machine but displaying it on another), you will need to use the "trusted forwarding" mode of SSH in order for the Tcl/Tk generated graphics, such as d.m or gis.m in order for the GUI graphics to make it through your connection. This can be done using the -Y flag when you start the ssh session:
ssh -Y remotehost
or add this to ~/.ssh/config:
Host hostname
  ForwardX11 yes
  ForwardX11Trusted yes
Using the -X flag, or simply turning on X11Forwarding in the SSH configuration files, is not enough: the symptoms in this case are that a d.mon window will function fine, but none of the Tcl/Tk dialogues will work, failing with an error message complaining either about Wish not behaving as expected, or a "Bad Atom".
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
