Vector topology cleaning
From GRASS-Wiki
Jump to: navigation, search
Q: How can I patch to fitting area maps with have been digitized separately and correct the topology? I observe that the shared polygon boundaries do not perfectly match...
Polygon vector map with topology problems
A: You can use v.clean for this.
Tools to consider:
  • TBD
Q: How about self-intersecting lines and boundaries?
A: In the GRASS topological model self-intersecting lines are allowed, self-intersecting boundaries are not. Self-intersecting lines are ok e.g. for v.net modules, e.g. to represent a bridge of a secondary road over a highway.
Note: There are some modules that do not like self-intersecting lines, e.g with v.buffer problems are expected.
Polygon import from SHAPE file:
Overlayed polygons after import from SHAPE file (Simple Features
v.clean applied:
Overlayed polygons topologically cleaned. Note the double categories.
See also
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
