WxGUI Cartographic Composer
Back to wxGUI.
For development issues see Trac page.
Contents |
ps.map (see also ps.output) is a cartographic composer, intended to be a stand-alone hardcopy plot generator. It is not meant to be a Print button for the maps currently displayed in the map canvas, that will need it own controls.
The Cartographic Composer (so called wx.psmap) is a GUI application which allows GRASS users to prepare interactively hardcopy map outputs. The application can write a instructions file for GRASS module ps.map, and then run this module on the background to create PostScript output directly. See the announcement in the mailing list.
The Cartographic Composer is available in GRASS 6.4.2+ from the menu
File -> Cartographic Composer
or from the toolbar
The GUI currently supports the most important mapping instructions
- paper
- scale
- maploc
- rast
- vects
- scalebar
- mapinfo
- legend
- text labels
- eps (image, north arrow)
Video tutorial
How to add north arrow
Raster, legend, vector outline
Input
- Ability to load in saved ps.map instructions file. I consider this to be a low priority, deal with it after map creation is fully functional. Start with scripts saved using the GUI, after that is working expand to load any ps.map instructions file.
Outputs
- ps.map instructions file
- PostScript file
- PDF file
Map Output Examples
data source: FreeGeodataCZ
data source: ZABAGED (http://www.cuzk.cz)
Examples were created within A. Kratochvilova's bachelor thesis
