NAME
i.nightlights.intercalibration  - Performs inter-satellite calibration on DMSP-OLS Nighttime Lights Time Series
KEYWORDS
imagery,
inter-satellite,
calibration,
nighttime lights,
time series,
DMSP-OLS
SYNOPSIS
i.nightlights.intercalibration --help
i.nightlights.intercalibration [-ciegxznt] image=name[,name,...] suffix=suffix model=author  [--overwrite]  [--help]  [--verbose]  [--quiet]  [--ui]
Flags:
- -c
- Print out citation for selected calibration model
- -i
- Print out calibration equations
- -e
- Evaluation based on the Normalised Difference Index
- -g
- Print in shell script style (currently only NDI via -e)
- -x
- Match computational region to extent of input image
- -z
- Exclude zero values from the analysis (retain zero cells in output)
- -n
- Exclude zero values from the analysis (set zero cells to NULL in output)
- -t
- Do not try to transfer timestamps (for input without timestamp)
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- image=name[,name,...] [required]
- Clean average DMSP-OLS visible band digital number image(s)
- suffix=suffix [required]
- output file(s) suffix
- Suffix for calibrated average digital number output image(s)
- Default: c
- model=author [required]
- Calibration model
- Inter-satellite calibration model for average DMSP-OLS nighttime lights time series
- Options: elvidge2009, elvidge2014, liu2012, wu2013
- Default: elvidge2014
i.nightlights.intercalibration is a GRASS GIS module performing
inter-satellite calibration on DMSP-OLS nighttime lights time series.
Based on "well known" emprirical regression models, it
calibrates average visible band Digital Number values.
| DNi +--> |Calibration Model| +--> Calibrated DN                      |
|              |             +--Evaluation+Methods-------------------+ |
| +--Regression+Models-----------------------------------------------+ |
| | Elvidge, 2009/2014: DNc = C0 + C1xDN + C2xDNv2                   | |
| | Liu,2012: based on Elvidge's model + optimal threshold method    | |
| | Wu, 2014:           DNc + 1 = ax(DN + 1)^b                       | |
| | Others?                                                          | |
From a review paper:
"Several methods were proposed to overcome the lack of inter-satellite
calibration. These include the invariant region and the quadratic regression
method proposed by Elvidge et al. [23], the second-order regression and optimal
threshold method proposed by Liu et al. [24], and a power-law regression method
proposed by Wu et al. [25]. Although studies based on these calibration methods
showed performance improvement after the rectification [24,25], the assumption
that the nighttime light remains stable over time in a particular area requires
a careful choice of the invariant region manually." [Huang 2014]
References above are:
[23] [Elvidge 2009]
[24] [Liu 2012]
[25] [Wu 2013]
Given all maps are imported in GRASS' data base, which are:
g.list rast pattern="F*"
F101992
F101993
F101994
F121994
F121995
F121996
F121997
F121998
F121999
F141997
F141998
F141999
F142000
F142001
F142002
F142003
F152000
F152001
F152002
F152003
F152004
F152005
F152006
F152007
F162004
F162005
F162006
F162007
F162008
F162009
F182010
F182011
F182012
the default inter-calibration, based on [Elvidge 2014], can be performed as:
i.nightlights.intercalibration image=$(g.list rast pattern="F*" sep=comma) suffix=calib_elv
An improved inter-calibration model is based on [Wu 2013], can be performed
as:
i.nightlights.intercalibration image=$(g.list rast pattern="F*stable_lights*" sep=comma) model=wu2013 suffix=calib_wu
In case the calibration models do not include regression coefficients for all of the
yearly products, the module will fail and inform with an error message like:
i.nightlights.intercalibration image=$(g.list rast pattern="F??????" sep=comma) model=liu2012 --v
... ValueError: The selected model does not know about this combination of
Satellite + Year!
To be added...
in general:
- improve missing key handling and error reporting
- code deduplication
- test -- will it compile in other systems?
in i.nightlights.intercalibration.py:
- use
*args or **kwargs where appropriate
in calibration_models.py:
- improve checks for missing combinations of Satellite + Year in models
- separate test_function from this "module"
another module?
- Accuracy assessment of inter-calibrated nighttime lights time series [Wu
  2013]:
    TLI = SUMi DNi * Ci where DNi is the grey value of i-level pixels
    and Ci is the number of i-level pixels
Review paper
- Huang, Q., Yang, X., Gao, B., Yang, Y., Zhao, Y., 2014. Application of DMSP/OLS Nighttime Light Images: A Meta-Analysis and a Systematic Literature Review. Remote Sensing 6, 6844-6866. https://doi.org/10.3390/rs6086844
Empirical second order regression model by Elvidge, 2009 | Y = C0 + C1*X + C2*X^2
- Zhang, L., Qu, G., Wang, W., 2015. Estimating Land Development Time Lags in China Using DMSP/OLS Nighttime Light Image. Remote Sensing 7, 882-904. https://doi.org/10.3390/rs70100882
- Elvidge, C.D., Hsu, F.-C., Baugh, K.E., Ghosh, T., 2014. National trends in satellite-observed lighting. Global urban monitoring and assessment through earth observation 23, 97-118.
- Fan, J., Ma, T., Zhou, C., Zhou, Y., Xu, T., 2014. Comparative Estimation of Urban Development in China's Cities Using Socioeconomic and DMSP/OLS Night Light Data. Remote Sensing 6, 7840-7856. https://doi.org/10.3390/rs6087840
- Shao, Z., Liu, C., 2014. The Integrated Use of DMSP-OLS Nighttime Light and MODIS Data for Monitoring Large-Scale Impervious Surface Dynamics: A Case Study in the Yangtze River Delta. Remote Sensing 6, 9359-9378. https://doi.org/10.3390/rs6109359
- Xu, T., Ma, T., Zhou, C., Zhou, Y., 2014. Characterizing Spatio-Temporal Dynamics of Urbanization in China Using Time Series of DMSP/OLS Night Light Data. Remote Sensing 6, 7708-7731. https://doi.org/10.3390/rs6087708
- Small, C., Elvidge, C.D., 2013. Night on Earth: Mapping decadal changes of anthropogenic night light in Asia. International Journal of Applied Earth Observation and Geoinformation, Spatial Statistics for Mapping the Environment 22, 40-52. https://doi.org/10.1016/j.jag.2012.02.009
Second order regression model & optimal threshold method by Liu, 2012
- Liang, H., Tanikawa, H., Matsuno, Y., Dong, L., 2014. Modeling In-Use Steel Stock in China's Buildings and Civil Engineering Infrastructure Using Time-Series of DMSP/OLS Nighttime Lights. Remote Sensing 6, 4780-4800. https://doi.org/10.3390/rs6064780
- Gao, B., Huang, Q., He, C., Ma, Q., 2015. Dynamics of Urbanization Levels in China from 1992 to 2012: Perspective from DMSP/OLS Nighttime Light Data. Remote Sensing 7, 1721-1735. https://doi.org/10.3390/rs70201721
Non-linear, power regression model
- Wu, J., He, S., Peng, J., Li, W., Zhong, X., 2013. Intercalibration of DMSP-OLS night-time light data by the invariant region method. International Journal of Remote Sensing 34, 7356-7368. https://doi.org/10.1080/01431161.2013.820365
Nikos Alexandris
SOURCE CODE
  Available at:
  i.nightlights.intercalibration source code
  (history)
  Latest change: Monday Jun 28 07:54:09 2021 in commit: 1cfc0af029a35a5d6c7dae5ca7204d0eb85dbc55
Main index |
Imagery index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
