NAME
i.segment.hierarchical  - Hierarchical segmentation
KEYWORDS
imagery,
segment
SYNOPSIS
i.segment.hierarchical --help
i.segment.hierarchical group=name thresholds=float[,float,...] output=name  [outputs_prefix=string]   [method=string]   [similarity=string]   [minsizes=integer[,integer,...]]   [memory=integer]   [iterations=integer]   [seeds=name]   [bounds=name]   [width=integer]   [height=integer]   [overlap=integer]   [processes=integer]   [move=string]   [--overwrite]  [--help]  [--verbose]  [--quiet]  [--ui]
Flags:
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- group=name [required]
- Name of input imagery group
- thresholds=float[,float,...] [required]
- Segment thresholds
- Default: 0.02,0.05
- output=name [required]
- Name of output sement raster map
- outputs_prefix=string
- Name for output raster maps from segment
- Default: seg__%.2f
- method=string
- Segmentation method
- Default: region_growing
- similarity=string
- Similarity calculation method
- Default: euclidean
- minsizes=integer[,integer,...]
- Minimum number of cells in a segment
- memory=integer
- Memory in MB
- Default: 300
- iterations=integer
- Maximum number of iterations
- Default: 20
- seeds=name
- Name for input raster map with starting seeds
- bounds=name
- Name of input bounding/constraining raster map
- width=integer
- Tile width in pixels
- height=integer
- Tile height in pixels
- overlap=integer
- Tile overlap in pixels
- Default: 0
- processes=integer
- Number of concurrent processes
- move=string
- Path where move and copy the mapset
i.segment.hierarchical performs a hierarchical segmentation on
a image (group). The module uses
i.segment.
TODO
i.segment
Pietro Zambelli (University of Trento)
SOURCE CODE
  Available at:
  i.segment.hierarchical source code
  (history)
  Latest change: Monday Jun 28 07:54:09 2021 in commit: 1cfc0af029a35a5d6c7dae5ca7204d0eb85dbc55
Main index |
Imagery index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
