NAME
r.green.biomassfor.financial - Estimates bioenergy that can be collected to supply heating plants or biomass logistic centres and that is associated with a positive net revenue for the entire production process
KEYWORDS
raster,
biomass
SYNOPSIS
r.green.biomassfor.financial --help
r.green.biomassfor.financial [-r] forest=name dhp=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_column_wood_price=string forest_roads=name main_roads=name elevation=name [technical_bioenergy=name] [tech_bioc=name] [tech_biohf=name] [soilp2_map=name] [tree_diam=name] [tree_vol=name] [rivers=name] [lakes=name] [forest_column_roughness=string] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [price_energy_woodchips=float] [cost_chainsaw=float] [cost_processor=float] [cost_harvester=float] [cost_cablehf=float] [cost_cablec=float] [cost_forwarder=float] [cost_skidder=float] [cost_chipping=float] [cost_transport=float] [ton_tops_hf=float] [ton_vol_hf=float] [ton_tops_cop=float] econ_bioenergy=name net_revenues=name [total_revenues=name] [total_cost=name] [econ_bioenergyhf=name] [econ_bioenergyc=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -r
- Remove all operational maps
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- forest=name [required]
- Name of vector parcel map
- dhp=name [required]
- Name of vector district heating points
- forest_column_yield=string [required]
- Vector field of yield
- forest_column_yield_surface=string [required]
- Vector field of stand surface (ha)
- forest_column_management=string [required]
- Vector field of forest management (1: high forest, 2:coppice)
- forest_column_treatment=string [required]
- Vector field of forest treatment (1: final felling, 2:thinning)
- forest_column_wood_price=string [required]
- Vector field of wood prices
- forest_roads=name [required]
- Vector map of forest roads
- main_roads=name [required]
- Vector map of main roads
- elevation=name [required]
- Name of input elevation raster map
- technical_bioenergy=name
- Total technical biomass potential [MWh/year]
- tech_bioc=name
- Technical biomass potential for coppices [MWh/year]
- tech_biohf=name
- Technical biomass potential in high forest [MWh/year]
- soilp2_map=name
- Soil production map
- tree_diam=name
- Average tree diameter map
- tree_vol=name
- Average tree volume map
- rivers=name
- Vector map of rivers
- lakes=name
- Vector map of lakes
- forest_column_roughness=string
- Vector field of roughness
- slp_min_cc=float
- Percent slope lower limit with Cable Crane
- Default: 30.
- slp_max_cc=float
- Percent slope higher limit with Cable Crane
- Default: 100.
- dist_max_cc=float
- Maximum distance with Cable Crane
- Default: 800.
- slp_max_fw=float
- Percent slope higher limit with Forwarder
- Default: 30.
- dist_max_fw=float
- Maximum distance with Forwarder
- Default: 600.
- slp_max_cop=float
- Percent slope higher limit with other techniques for Coppices
- Default: 30.
- dist_max_cop=float
- Maximum distance with other techniques for Coppices
- Default: 600.
- price_energy_woodchips=float
- Price for energy from woodchips EUR/MWh
- Default: 19.50
- cost_chainsaw=float
- Felling and/or felling-processing cost with chainsaw EUR/h
- Default: 13.17
- cost_processor=float
- Processing cost with processor EUR/h
- Default: 87.42
- cost_harvester=float
- Felling and processing cost with harvester EUR/h
- Default: 96.33
- cost_cablehf=float
- Extraction cost with high power cable crane EUR/h
- Default: 111.44
- cost_cablec=float
- Extraction cost with medium power cable crane EUR/h
- Default: 104.31
- cost_forwarder=float
- Extraction cost with forwarder EUR/h
- Default: 70.70
- cost_skidder=float
- Extraction cost with skidder EUR/h
- Default: 64.36
- cost_chipping=float
- Chipping cost EUR/h
- Default: 150.87
- cost_transport=float
- Transport with truck EUR/h
- Default: 64.90
- ton_tops_hf=float
- BEF for tops and branches in high forest [ton/m3]
- Default: 0.25
- ton_vol_hf=float
- BEF for the whole tree in high forest (tops, branches and stem) in ton/m3
- Default: 1
- ton_tops_cop=float
- BEF for tops and branches for Coppices in ton/m3
- Default: 0.28
- econ_bioenergy=name [required]
- Name of raster map with the financial potential of bioenergy [Mwh/year]
- net_revenues=name [required]
- Name of raster map with the net present value [EUR/year]
- Default: net_revenues
- total_revenues=name
- Name of raster map with the total revenues [EUR/year]
- total_cost=name
- Name of raster map with the total cost [EUR/year]
- econ_bioenergyhf=name
- Name of raster map with the financial potential of bioenergy in high forest [Mwh/year]
- econ_bioenergyc=name
- Name of raster map with the financial potential of bioenergy for coppices[Mwh/year]
Compute the biomass forestry residual potential considering the economic constraints.
r.green,
r.green.biomassfor
Francesco Geri,
Pietro Zambelli,
Sandro Sacchelli,
Marco Ciolli
Code rewritten by Giulia Garegnani
SOURCE CODE
Available at:
r.green.biomassfor.financial source code
(history)
Accessed: Sunday Nov 09 05:28:24 2025
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
