NAME
r.green.biomassfor.technical  - Estimates the quantity of woody biomass obtained from a forest surface where extraction is possible given a particular level of mechanisation
KEYWORDS
raster,
biomass
SYNOPSIS
r.green.biomassfor.technical --help
r.green.biomassfor.technical [-r] dtm=name forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name output_basename=name  [forest_column_roughness=string]   [rivers=name]   [lakes=name]   [slp_min_cc=float]   [slp_max_cc=float]   [dist_max_cc=float]   [slp_max_fw=float]   [dist_max_fw=float]   [slp_max_cop=float]   [dist_max_cop=float]   [energy_tops_hf=float]   [energy_cormometric_vol_hf=float]   [energy_tops_cop=float]   [--overwrite]  [--help]  [--verbose]  [--quiet]  [--ui]
Flags:
- -r
- Remove all operational maps
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- dtm=name [required]
- Name of Digital terrain model map
- forest=name [required]
- Name of vector parcel map
- boundaries=name [required]
- Name of vector boundaries map (boolean map)
- forest_column_yield=string [required]
- Vector field of yield
- forest_column_yield_surface=string [required]
- Vector field of stand surface (ha)
- forest_column_management=string [required]
- Vector field of forest management (1: high forest, 2:coppice)
- forest_column_treatment=string [required]
- Vector field of forest treatment (1: final felling, 2:thinning)
- forest_roads=name [required]
- Vector map of forest roads
- output_basename=name [required]
- Basename for technical bioenergy (HF,CC and total)
- forest_column_roughness=string
- Vector field of roughness
- rivers=name
- Vector map of rivers
- lakes=name
- Vector map of lakes
- slp_min_cc=float
- Percent slope lower limit with Cable Crane
- Default: 30.
- slp_max_cc=float
- Percent slope higher limit with Cable Crane
- Default: 100.
- dist_max_cc=float
- Maximum distance with Cable Crane
- Default: 800.
- slp_max_fw=float
- Percent slope higher limit with Forwarder
- Default: 30.
- dist_max_fw=float
- Maximum distance with Forwarder
- Default: 600.
- slp_max_cop=float
- Percent slope higher limit with other techniques for Coppices
- Default: 30.
- dist_max_cop=float
- Maximum distance with other techniques for Coppices
- Default: 600.
- energy_tops_hf=float
- Energy for tops and branches in high forest in MWh/m3
- Default: 0.49
- energy_cormometric_vol_hf=float
- Energy for the whole tree in high forest (tops, branches and stem) in MWh/m3
- Default: 1.97
- energy_tops_cop=float
- Energy for tops and branches for Coppices in MWh/m3
- Default: 0.55
Compute the biomass forestry residual potential considering the technical
constraints of different harvesting techniques.
  r.green,
  r.green.biomassfor
Francesco Geri,
Pietro Zambelli,
Sandro Sacchelli,
Marco Ciolli
SOURCE CODE
  Available at:
  r.green.biomassfor.technical source code
  (history)
  Latest change: Monday Jun 28 07:54:09 2021 in commit: 1cfc0af029a35a5d6c7dae5ca7204d0eb85dbc55
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
