NAME
d.vect.colbp - Draws the boxplot of values in a vector attribute column
KEYWORDS
display,
vector,
plot,
histogram,
boxplot
SYNOPSIS
d.vect.colbp
d.vect.colbp --help
d.vect.colbp [-honr] map=name [layer=string] column=name [where=sql_query] [plot_output=name] [group_by=name] [order=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -h
- horizontal boxplot(s)
- Draw the boxplot horizontal
- -o
- hide outliers
- Draw boxplot(s) without outliers
- -n
- notch
- Draw boxplot(s) with notch
- -r
- Rotate labels
- rotate x-axis labels
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name [required]
- Name of vector map
- Or data source for direct OGR access
- layer=string
- Layer number or name
- Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
- Default: 1
- column=name [required]
- Attribute column value to be plotted
- where=sql_query
- WHERE conditions of SQL statement without 'where' keyword
- Example: income < 1000 and population >= 10000
- plot_output=name
- Name for output file
- group_by=name
- Attribute column with categories to group the data by
- order=string
- Sort boxplots
- Sort boxplots based on their median values
- Options: descending, ascending
d.vect.colbp draws a boxplot of the values in a vector
map attribute column. The user can use the
where option to only select a subset of the attribute table.
There is also the option to group the values of the column according to
the categories in a second column (group_by and create one plot
with for each group a separate boxplot.
By default, the resulting plot is displayed on screen (default).
However, the user can also save the plot to file using the
plot_output option. The format is determined by the extension
given by the user. So, if plot_output = outputfile.png, the plot will
be saved as a png file.
There are a few additonal layout options, including the option to rotate
the plot and the x-axis labels. Furthermore, the user can optinally plot
the boxplot(s) with notches and without outliers.
This script, based on d.vect.colhist, is a quick and dirty solution
sing basic matplotlib, and will need some further fine-tuning and
testing.
Use the vector layer
schools_wake from the
NC sample
dataset to create boxplots of the core capacity of the schools in
Wake County, North Carolina. Use the
Where clause to exclude
all records with no data.
d.vect.colbp -n map=schools_wake column=CORECAPACI where="CORECAPACI >0"
Figure 1: Boxplot of core capacity of schools in Wake County.
NC sample
Wake County, North Carolina, grouped by city. Use the
Where
clause to exclude all records with no data.
d.vect.colbp -h --overwrite map=schools_wake column=CORECAPACI where="CORECAPACI >0" group_by=ADDRCITY order=ascending
Figure 2" Boxplot of core capacity of schools in Wake County, grouped by city.
Paulo van Breugel
Based on the d.vect.colhist addon by Moritz Lennert
SOURCE CODE
Available at:
d.vect.colbp source code
(history)
Latest change: Monday Jan 30 19:52:26 2023 in commit: cac8d9d848299297977d1315b7e90cc3f7698730
Main index |
Display index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 8.3.2dev Reference Manual
