GRASS logo
NAME
v.select - Select features from ainput by features from binput
KEYWORDS
vector
SYNOPSIS
v.select
v.select help
v.select [-t] ainput=name [atype=string[,string,...]] [alayer=integer] binput=name [btype=string[,string,...]] [blayer=integer] output=name [operator=string] [--overwrite]
Flags:
-t
Do not create attribute table
--overwrite
Force overwrite of output files
Parameters:
ainput=name
Name of input vector map
Type
Options: point,line,boundary,centroid,area
Default: point,line,boundary,centroid,area
alayer=integer
Layer number
Default: 1
binput=name
Type
blayer=integer
Layer number
Default: 1
output=name
Name for output vector map
operator=string
Operator defines required relation between features. A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.
overlap: features partially or completely overlap
Options: overlap
Default: overlap
DESCRIPTION
v.select allows the user to select features from a vector by features from another one.
NOTES
EXAMPLES
Extract forest fire points from larger fire map:
v.select ainput=fire binput=forest output=forest_fire
Extract Italian rivers from VMAP0 watercourses map:
v.select ain=watrcrsl_eurnasia_wgs84 bin=italy_area \
         out=watrcrsl_italy op=overlap
SEE ALSO
v.overlay, GRASS SQL interface
AUTHORS
Radim Blazek
Last changed: $Date: 2007/03/22 08:00:33 $
Main index - vector index - Full index
