GRASS logo
NAME
v.to.rast - Converts a binary GRASS vector map layer into a GRASS raster map layer.
KEYWORDS
vector
SYNOPSIS
v.to.rast
v.to.rast help
v.to.rast input=name output=name [use=string] [column=name] [layer=integer] [value=float] [rows=integer] [--overwrite]
Flags:
--overwrite
Force overwrite of output files
Parameters:
input=name
Name of input vector map
output=name
Name for output raster map
use=string
Source of raster values:
attr - read values from attribute table
cat - use category values
val - use value specified by value option
z - use z coordinate (points or contours only)
dir - output as flow direction (lines only)
Options: attr,cat,val,z,dir
Default: attr
column=name
Column name (type must be numeric)
layer=integer
Layer number
Default: 1
value=float
Raster value
Default: 1
rows=integer
number of rows to hold in memory
Default: 4096
DESCRIPTION
v.to.rast transforms GRASS vector map layers into GRASS raster map layer format.
NOTES
v.to.rast will only affect data in areas lying inside the boundaries of the current geographic region. Before running v.to.rast, the user should therefore ensure that the current geographic region is correctly set and that the region resolution is at the desired level.
Either the column parameter or the value parameter must be specified. The use option may be specified alone when using the dir option.
use options are:
The column parameter uses an existing column from the vector map database table as the category value in the output raster map. Existing table columns can be shown by using db.describe.
An empty raster map layer will be created if the vector map layer has not been assigned category/attribute labels (e.g., through use of v.category option=add).
Otherwise:
Flow directions are given in degrees counterclockwise from east.
EXAMPLES
1. Convert a vector map and use column SPEED from attribute table
db.describe -c table=vect_map
ncols:3
Column 1: CAT
Column 2: SPEED
Column 3: WIDTH
v.to.rast in=vect_map out=raster_map col=SPEED
2. Calculate stream directions from a river vector map (Spearfish)
v.to.rast in=streams out=streamsdir use=dir
SEE ALSO
db.describe, v.category
AUTHORS
Original code: Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
GRASS 6 updates: Radim Blazek, ITC-Irst, Trento, Italy
Stream directions: Jaro Hofierka and Helena Mitasova
Last changed: $Date: 2007/01/28 16:30:34 $
Main index - vector index - Full index
