NAME
v.to.rast - Converts a binary GRASS vector map layer into a GRASS raster map layer.
KEYWORDS
vector, raster, conversion
SYNOPSIS
v.to.rast
v.to.rast help
v.to.rast input=name output=name [use=string] [type=string[,string,...]] [layer=integer] [column=name] [value=float] [rows=integer] [rgbcolumn=name] [labelcolumn=name] [--overwrite] [--verbose] [--quiet]
Flags:
- --overwrite
- Allow output files to overwrite existing files
- --verbose
- Verbose module output
- --quiet
- Quiet module output
Parameters:
- input=name
- Name of input vector map
- output=name
- Name for output raster map
- use=string
- Source of raster values
- Options: attr,cat,val,z,dir
- Default: attr
- attr: read values from attribute table
- cat: use category values
- val: use value specified by value option
- z: use z coordinate (points or contours only)
- dir: output as flow direction (lines only)
- type=string[,string,...]
- Type
- Feature type(s)
- Options: point,line,area
- Default: point,line,area
- layer=integer
- Layer number
- A single vector map can be connected to multiple database tables. This number determines which table to use.
- Default: 1
- column=name
- Name of column for attr parameter (data type must be numeric)
- value=float
- Raster value
- Default: 1
- rows=integer
- Number of rows to hold in memory
- Default: 4096
- rgbcolumn=name
- Name of color definition column (with RRR:GGG:BBB entries)
- labelcolumn=name
- Name of column used as raster category labels
DESCRIPTION
v.to.rast transforms GRASS vector map layers into GRASS raster map
layer format. Optionally, attributes can be converted into raster category
labels.
NOTES
v.to.rast will only affect data in areas lying
inside the boundaries of the current geographic region.
Before running v.to.rast, the user should
therefore ensure that the current geographic region is
correctly set and that the region resolution is at the
desired level.
Either the column parameter or the value
parameter must be specified. The use option may be
specified alone when using the dir option.
use options are:
attr - read values from attribute table (default)
cat - read values from category
val - use value specified by value option
z - use z coordinate (points or contours only)
dir - output as flow direction in degrees (lines only)
The column parameter uses an existing column from the vector map
database table as the category value in the output raster map. Existing table
columns can be shown by using db.describe.
An empty raster map layer will be created if the vector map layer has not
been assigned category/attribute labels (e.g., through use of
v.category option=add).
Otherwise:
Labeled areas and/or centroids will produce filled raster coverages with edges
that straddle the original area boundary as long as the boundary is NOT
labeled.
(Use v.category option=del type=boundary to remove.)
Labeled lines and boundaries will produce lines of raster cells which touch the
original vector line. This tends to be more aggressive than area-only conversions.
Points and orphaned centroids will be converted into single cells on the
resultant raster map.
Flow directions are given in degrees counterclockwise from east.
Raster category labels are supported for all of use= except use=z.
EXAMPLES
1. Convert a vector map and use column SPEED from attribute table
db.describe -c table=vect_map
ncols:3
Column 1: CAT
Column 2: SPEED
Column 3: WIDTH
v.to.rast in=vect_map out=raster_map col=SPEED
2. Calculate stream directions from a river vector map (Spearfish)
v.to.rast in=streams out=streamsdir use=dir
3. Convert a vector polygon map to raster including descriptive labels (Spearfish)
v.to.rast in=fields out=myfields use=attr col=cat labelcol=label
r.category myfields
SEE ALSO
db.describe,
v.category
AUTHORS
Original code: Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
GRASS 6.0 updates: Radim Blazek, ITC-irst, Trento, Italy
Stream directions: Jaro Hofierka and Helena Mitasova
GRASS 6.3 code cleanup and label support: Brad Douglas
Last changed: $Date: 2008-02-19 12:12:24 -0800 (Tue, 19 Feb 2008) $
Main index - vector index - Full index
© 2003-2008 GRASS Development Team
