The pseudo-kurtosis factor is used with all other methods to control the slope steepness. For the Gaussian method setting the value nearer to zero creates a flatter surface, while higher values generate steeper slopes. For Lorentzian, logarithmic, and exponential methods the opposite is true.
The surface roughness factor controls the fixed standard deviation distance (sigma) used in the Gaussian random number generator. It is only used when the -r roughen surface flag is turned on. A value closer to zero makes a smoother surface, a higher value makes a rougher surface.
It is possible to set a negative value for the peak in order to create a pit.
r.surf.volcano -r output=seamount # view in the display monitor r.colors seamount color=sepia -e d.rast seamount # view in 3D r.colors seamount color=srtm nviz seamount # export to Matlab r.out.mat in=seamount out=seamount.mat # integrate into existing DEM r.mapcalc "seamount_dem=if(seamount > dem, seamount, dem)" r.colors seamount_dem color=srtm
r.surf.volcano -r output=volcano crater=250 --verbose r.shaded.relief volcano
r.surf.volcano -r output=base_volcano peak=600 crater=120 r.surf.fractal output=base_fractal r.mapcalc "artificial_land = base_volcano + base_fractal" r.colors artificial_land color=srtm nviz artificial_land
Last changed: $Date$
Main index - raster index - Full index
© 2003-2016 GRASS Development Team
