Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
For flags, the value will be "1" if the flag was given, and "0" otherwise.
If the -s switch is used, the options and flags are written to standard output in the form opt_<name>=<value> and flag_<name>=<value>, preceded by the string @ARGS_PARSED@. If this string doesn't appear as the first line of standard output, it indicates that the script was invoked with a switch such as --html-description. In this case, the data written by g.parser to standard output should be copied to the script's standard output verbatim.
Typical header definitions are as follows:
#%module #% description: g.parser test script #%end #%flag #% key: f #% description: A flag #%end #%option #% key: raster #% type: string #% gisprompt: old,cell,raster #% description: Raster input map #% required : yes #%end
#% multiple : yesWhile this will only directly change the Usage section of the help screen, the option's environmental string may be easily parsed from within a script. For example, individual comma separated identities for an option named "input" can be parsed with the following Bash shell code:
IFS=,
for opt in $GIS_OPT_INPUT ; do
... "$opt"
done
A "guisection" field may be added to each option and flag to specify that the options should appear in multiple tabs in the auto-generated GUI. Any options without a guisection field go into the "Options" tab. For example:
#% guisection: tabnamewould put that option in a tab named tabname.
A "key_desc" field may be added to each option to specify the text that appears in the module's usage help section. For example:
#% key_desc: filenameadded to an input option would create the usage summary [input=filename].
If a script is run with --o, G_parser() will set GRASS_OVERWRITE=1, which has the same effect as passing --o to every module which is run from the script. Similarly, passing --q or --v will set GRASS_VERBOSE to 0 or 3 respectively, which has the same effect as passing --q or --v to every module which is run from the script. Rather than checking whether --o, --q or --v were used, you should be checking GRASS_OVERWRITE and/or GRASS_VERBOSE instead. If those variables are set, the script should behave the same way regardless of whether they were set by --o, --q or --v being passed to the script or set by other means.
v.in.db --script
v.in.db --html-description
v.in.db --interface-description
v.in.db --tcltk
g.parser -t somescriptfile
#!/bin/sh
# g.parser demo script for shell programing
#%module
#%end
#%flag
#% key: f
#%end
#%option
#% key: raster
#% type: string
#% required : yes
#%end
#%option
#% key: vector
#% type: string
#% gisprompt: old,vector,vector
#% description: Vector input map
#% required : yes
#%end
#%option
#% key: option1
#% type: string
#% description: An option
#% required : no
#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." 1>&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
#### add your code below ####
echo ""
if [ $GIS_FLAG_F -eq 1 ] ; then
echo "Flag -f set"
else
echo "Flag -f not set"
fi
# test if parameter present:
if [ -n "$GIS_OPT_OPTION1" ] ; then
echo "Value of GIS_OPT_OPTION1: '$GIS_OPT_OPTION1'"
fi
echo "Value of GIS_OPT_RASTER: '$GIS_OPT_RASTER'"
echo "Value of GIS_OPT_VECTOR: '$GIS_OPT_VECTOR'"
test.sh --help Description: g.parser test script (python) Usage: test.sh [-f] raster=string vector=string [option1=string] [--verbose] [--quiet] Flags: -f A flag --v Verbose module output --q Quiet module output Parameters: raster Raster input map vector Vector input map option1 An option
#!/usr/bin/env python
# g.parser demo script for python programing
#%module
#% description: g.parser test script (python)
#%end
#%flag
#% key: f
#%end
#%option
#% key: raster
#% type: string
#% required : yes
#%end
#%option
#% key: vector
#% type: string
#% required : yes
#%end
#%option
#% key: option1
#% type: string
#% required : no
#%end
import os
import sys
import grass.script as grass
def main():
flag_f = flags['f']
option1 = options['option1']
raster = options['raster']
vector = options['vector']
#### add your code here ####
if flag_f:
print "Flag -f set"
else:
print "Flag -f not set"
if option1:
print "Value of option1 option: '%s'" % option1
print "Value of raster option: '%s'" % raster
print "Value of vector option: '%s'" % vector
#### end of your code ####
return 0
if __name__ == "__main__":
options, flags = grass.parser()
main()
./test.py --help Description: g.parser test script (python) Usage: test1.py [-f] raster=string vector=string [option1=string] [--verbose] [--quiet] Flags: -f A flag --v Verbose module output --q Quiet module output Parameters: raster Raster input map vector Vector input map option1 An option
#!/usr/bin/perl -w
use strict;
#%module
#% description: g.parser test script (perl)
#% keywords: keyword1, keyword2
#%end
#%flag
#% key: f
#%end
#%option
#% key: raster
#% type: string
#% required : yes
#%end
#%option
#% key: vector
#% type: string
#% required : yes
#%end
#%option
#% key: option1
#% type: string
#% required : no
#%end
if ( !$ENV{'GISBASE'} ) {
printf(STDERR "You must be in GRASS GIS to run this program.\n");
exit 1;
if( $ARGV[0] ne '@ARGS_PARSED@' ){
my $arg = "";
for (my $i=0; $i < @ARGV;$i++) {
$arg .= " $ARGV[$i] ";
system("$ENV{GISBASE}/bin/g.parser $0 $arg");
exit;
print "\n";
if ( $ENV{'GIS_FLAG_F'} eq "1" ){
print "Flag -f set\n"
else {
print "Flag -f not set\n"
printf ("Value of GIS_OPT_option1: '%s'\n", $ENV{'GIS_OPT_OPTION1'});
printf ("Value of GIS_OPT_raster: '%s'\n", $ENV{'GIS_OPT_RASTER'});
printf ("Value of GIS_OPT_vect: '%s'\n", $ENV{'GIS_OPT_VECTOR'});
Related Wiki pages: Using GRASS with other programming languages
Last changed: $Date: 2014-01-25 11:04:22 -0800 (Sat, 25 Jan 2014) $
© 2003-2014 GRASS Development Team
