Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
SQLite driver in GRASS
Creating a SQLite database
GRASS is automatically creating the SQLite database if it is not yet
existing when the first table is created in the SQLite database. It
is sufficient to define the connection (see next step).
Connecting GRASS to SQLite
The database name 'sqlite.db' is at user's choice.
Also the file storage location can be freely chosen. If the database
does not exist, it will be automatically created when database content
is created:
# example for storing DB in mapset directory (keep single quotes):
db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
db.connect -p
Supported SQL commands
All SQL commands supported by SQLite (for limitations, see
SQLite help page:
SQL As Understood By SQLite and
Unsupported SQL).
Operators available in conditions
All SQL operators supported by SQLite.
Browsing table data in DB
A convenient SQLite front-end is sqlitebrowser.
To open a DB file stored within the current mapset,
the following way is suggested (corresponds to above database connection):
eval `g.gisenv`
# use double quotes:
sqlitebrowser "$GISDBASE/$LOCATION_NAME/$MAPSET"/sqlite.db
SEE ALSO
db.connect,
db.execute,
db.select
SQL support in GRASS GIS
SQLite web site,
SQLite manual,
sqlite - Management Tools
Last changed: $Date: 2012-09-07 01:51:36 -0700 (Fri, 07 Sep 2012) $
Main index -
database index -
full index
