Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
Costs may be either line lengths, or attributes saved in a
database table. These attribute values are taken as costs of whole
segments, not as costs to traverse a length unit (e.g. meter) of the
segment. For example, if the speed limit is 100 km / h, the cost to
traverse a 10 km long road segment must be calculated as
length / speed = 10 km / (100 km/h) = 0.1 h.
Supported are cost assignments for both arcs and nodes,
and also different costs for both directions of a vector line.
For areas, costs will be calculated along boundary lines.
The input vector needs to be prepared with v.net operation=connect in order to connect points representing center nodes to the network.
Center nodes can also be assigned to vector nodes using wxGUI vector digitizer.
1. Subnetwork allocation using distance:
2. Subnetwork allocation using traveling time:
Example 1: Calculating subnets for 3 center nodes using distances
# Spearfish # center nodes: echo "591235.5|4926306.62|1 596591.8|4917042.5|2 602722.9|4923544.2|3" | v.in.ascii in=- out=centernodes g.copy vect=roads,myroads # connect points to network v.net myroads points=centernodes out=myroads_net op=connect thresh=200 # allocate, specifying range of center cats (easier to catch all): v.net.alloc myroads_net out=myroads_net_alloc ccats=1-100000 nlayer=2 # report categories v.category myroads_net_alloc option=report
# show result g.region vect=myroads_net d.mon x0 d.vect myroads_net layer=1 # the result has to be selected by category number of the relevant node: d.vect myroads_net_alloc cat=1 col=red layer=1 d.vect myroads_net_alloc cat=2 col=green layer=1 d.vect myroads_net_alloc cat=3 col=yellow layer=1 # center nodes d.vect myroads_net col=red icon=basic/triangle fcol=green size=12 layer=2
Example 2: Calculating subnets for 3 center nodes using traveling time
# Spearfish # center nodes: echo "591235.5|4926306.62|1 596591.8|4917042.5|2 602722.9|4923544.2|3" | v.in.ascii in=- out=centernodes g.copy vect=roads,myroads # create lines map connecting points to network v.net myroads points=centernodes out=myroads_net op=connect thresh=500 alayer=1 nlayer=2 # set up costs # create unique categories for each road in layer 3 v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line # add new table for layer 3 v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision" # copy road type to layer 3 v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label # upload road length in miles v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles # set speed limits in miles / hour v.db.update myroads_net_time layer=3 col=speed val="5.0" v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'" v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'" v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'" v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'" v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'" # define traveling costs as traveling time in minutes: # set forward costs v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60" # set backward costs v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60" # subnetwork allocation with fastest paths v.net.alloc in=myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost out=myroads_net_alloc_time ccats=1-3
# show result g.region vect=myroads_net d.mon x0 d.vect myroads_net type=line layer=1 # the result has to be selected by category number of the relevant node: d.vect myroads_net_alloc_time cat=1 col=red layer=1 d.vect myroads_net_alloc_time cat=2 col=green layer=1 d.vect myroads_net_alloc_time cat=3 col=yellow layer=1 # center nodes d.vect myroads_net_time col=red icon=basic/triangle fcol=green size=12 type=point layer=2
Last changed: $Date: 2013-05-23 13:00:25 -0700 (Thu, 23 May 2013) $
Main index - vector index - Full index
© 2003-2014 GRASS Development Team
