Note: A new GRASS GIS stable version has been released: GRASS GIS 7.4, available here.
Updated manual page: here
For flags, the value will be "1" if the flag was given, and "0" otherwise.
If the -s or -n switch is used, the options and flags are written to standard output in the form opt_<name>=<value> and flag_<name>=<value>, preceded by the string @ARGS_PARSED@. If this string doesn't appear as the first line of standard output, it indicates that the script was invoked with a switch such as --html-description. In this case, the data written by g.parser to standard output should be copied to the script's standard output verbatim. If the -s switch is used, the options and flags are separated by newlines. If the -n switch is used, the options and flags are separated by null characters.
Typical header definitions are as follows:
#%module #% description: g.parser test script #%end #%flag #% key: f #% description: A flag #%end #%option #% key: raster #% type: string #% gisprompt: old,cell,raster #% description: Raster input map #% required: yes #%end
The parsers allows using predefined standardized options and flags, see the list of options and flags in the programmer manual. Eg. the option
#%option G_OPT_R_MAP #% key: raster #%end
#%rules #% exclusive: capfile_output, capfile #%end
#%rules #% required: raster, vector #%end
#%rules #% required: -i,-d,-c #%end
#% multiple: yes
IFS=, for opt in $GIS_OPT_INPUT ; do ... "$opt" done
A "guisection" field may be added to each option and flag to specify that the options should appear in multiple tabs in the auto-generated GUI. Any options without a guisection field go into the "Required" or "Options" tab. For example:
#% guisection: tabname
A "key_desc" field may be added to each option to specify the text that appears in the module's usage help section. For example:
#% key_desc: filename
If a script is run with --o, the parser will set GRASS_OVERWRITE=1, which has the same effect as passing --o to every module which is run from the script. Similarly, passing --q or --v will set GRASS_VERBOSE to 0 or 3 respectively, which has the same effect as passing --q or --v to every module which is run from the script. Rather than checking whether --o, --q or --v were used, you should be checking GRASS_OVERWRITE and/or GRASS_VERBOSE instead. If those variables are set, the script should behave the same way regardless of whether they were set by --o, --q or --v being passed to the script or set by other means.
For C, the relevant functions are those in lib/gis/parser_dependencies.c.
For scripts, relationships are specified using a "rules" section, e.g.
#%rules #% required: altitude,elevation #%end
v.in.db --script
v.in.db --html-description
v.in.db --interface-description
v.in.db --wps-process-description
v.in.db --rst-description
g.parser -t somescriptfile
To run properly, the script needs to be copied into a directory listed in $GRASS_ADDON_PATH environmental variable with the executable flag being set.
The script will provide a GUI (as above) and the following usage help text:
test.py|sh|pl --help Description: g.parser test script (python) Usage: test.sh [-f] raster=string vector=string [option1=string] [--verbose] [--quiet] Flags: -f A flag --v Verbose module output --q Quiet module output Parameters: raster Raster input map vector Vector input map option1 An option
#!/usr/bin/env python # g.parser demo script for python programming #%module #% description: g.parser test script (python) #% keyword: keyword1 #% keyword: keyword2 #%end #%flag #% key: f #% description: A flag #%end #%option G_OPT_R_MAP #% key: raster #% required: yes #%end #%option G_OPT_V_MAP #% key: vector #%end #%option #% key: option1 #% type: string #% description: An option #% required: no #%end import os import sys import grass.script as grass def main(): flag_f = flags['f'] option1 = options['option1'] raster = options['raster'] vector = options['vector'] #### add your code here #### if flag_f: print "Flag -f set" else: print "Flag -f not set" # test if parameter present: if option1: print "Value of option1 option: '%s'" % option1 print "Value of raster option: '%s'" % raster print "Value of vector option: '%s'" % vector #### end of your code #### return 0 if __name__ == "__main__": options, flags = grass.parser() sys.exit(main())
#!/bin/sh # g.parser demo script for shell programming #%module #% description: g.parser test script (shell) #%end #%flag #% key: f #% description: A flag #%end #%option G_OPT_R_MAP #% key: raster #% required: yes #%end #%option G_OPT_V_MAP #% key: vector #%end #%option #% key: option1 #% type: string #% description: An option #% required: no #%end if [ -z "$GISBASE" ] ; then echo "You must be in GRASS GIS to run this program." 1>&2 exit 1 fi if [ "$1" != "@ARGS_PARSED@" ] ; then exec g.parser "$0" "$@" fi #### add your code below #### echo "" if [ $GIS_FLAG_F -eq 1 ] ; then g.message message="Flag -f set" else g.message message="Flag -f not set" fi # test if parameter present: if [ -n "$GIS_OPT_OPTION1" ] ; then echo "Value of GIS_OPT_OPTION1: '$GIS_OPT_OPTION1'" fi g.message message="Value of GIS_OPT_option1: '$GIS_OPT_option1'" g.message message="Value of GIS_OPT_raster: '$GIS_OPT_raster'" g.message message="Value of GIS_OPT_vect: '$GIS_OPT_vector'" #### end of your code ####
#!/usr/bin/perl -w use strict; # g.parser demo script #%module #% description: g.parser test script (perl) #% keyword: keyword1 #% keyword: keyword2 #%end #%flag #% key: f #% description: A flag #%end #%option G_OPT_R_MAP #% key: raster #% required: yes #%end #%option G_OPT_V_MAP #% key: vector #%end #%option #% key: option1 #% type: string #% description: An option #% required: no #%end if ( !$ENV{'GISBASE'} ) { printf(STDERR "You must be in GRASS GIS to run this program.\n"); exit 1; } if( $ARGV[0] ne '@ARGS_PARSED@' ){ my $arg = ""; for (my $i=0; $i < @ARGV;$i++) { $arg .= " $ARGV[$i] "; } system("$ENV{GISBASE}/bin/g.parser $0 $arg"); exit; } #### add your code here #### print "\n"; if ( $ENV{'GIS_FLAG_F'} eq "1" ){ print "Flag -f set\n" } else { print "Flag -f not set\n" } printf ("Value of GIS_OPT_option1: '%s'\n", $ENV{'GIS_OPT_OPTION1'}); printf ("Value of GIS_OPT_raster: '%s'\n", $ENV{'GIS_OPT_RASTER'}); printf ("Value of GIS_OPT_vect: '%s'\n", $ENV{'GIS_OPT_VECTOR'}); #### end of your code ####
Overview table: Parser standard options
Related Wiki pages: Using GRASS GIS with other programming languages
Last changed: $Date: 2016-09-19 03:30:49 -0700 (Mon, 19 Sep 2016) $
Available at: g.parser source code (history)
Main index | General index | Topics index | Keywords index | Full index
© 2003-2018 GRASS Development Team, GRASS GIS 7.0.7svn Reference Manual
