GRASS logo
Note: A new GRASS GIS stable version has been released: GRASS GIS 7.8, available here.
Updated manual page: here
NAME
r.reclass.area - Reclasses a raster map greater or less than user specified area size (in hectares).
KEYWORDS
raster, statistics, aggregation
SYNOPSIS
r.reclass.area
r.reclass.area --help
r.reclass.area [-cd] input=name output=name value=float mode=string [method=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-c
Input map is clumped
-d
Clumps including diagonal neighbors
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
input=name [required]
Name of input raster map
output=name [required]
Name for output raster map
value=float [required]
Value option that sets the area size limit (in hectares)
mode=string [required]
Lesser or greater than specified value
Options: lesser, greater
method=string
Method used for reclassification
Options: reclass, rmarea
Default: reclass
Table of contents
DESCRIPTION
r.reclass.area reclasses a raster map greater or less than a user specified area size (in hectares).
If the -c flag is used, r.reclass.area will skip the creation of a clumped raster and assume that the input raster is already clumped.
EXAMPLES
In this example, the ZIP code map in the North Carolina sample dataset location is filtered for large areas (removing smaller areas from the map):
g.region raster=zipcodes -p
r.report zipcodes unit=h
# extract only areas greater than 2000 ha, NULL otherwise:
r.reclass.area input=zipcodes output=zipcodes_larger2000ha \
               mode=greater value=2000
r.report zipcodes_larger2000ha unit=h
In this example, the ZIP code map in the North Carolina sample dataset location is filtered for smaller areas which are substituted with the value of the respective adjacent area with largest shared boundary:
# reclass by substitutional removing of areas minor of 1000 ha
r.reclass.area input=zipcodes output=zipcodes_minor1000ha \
               mode=lesser value=1000 method=rmarea
SEE ALSO
r.reclass, r.clump, r.stats
AUTHORS
NRCS,
Markus Neteler
Last changed: $Date$
SOURCE CODE
Available at: r.reclass.area source code (history)
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2019 GRASS Development Team, GRASS GIS 7.4.5dev Reference Manual
