Note: A new GRASS GIS stable version has been released: GRASS GIS 7.8, available here.
 Updated manual page: here
The result is a new space time vector dataset that contains a single (new) vector map which links to as many time-stamped attribute tables as raster map layers are present in the input space time raster dataset. Hence, for each time step in the space time raster dataset a new attribute table is created. The GRASS GIS Temporal Framework allows to time stamp attribute tables that can be linked to a single vector map layer.
The module v.what.rast is used internally for sampling the time stamped raster map layers. All sampled values of a single time stamped raster map layer are written into a new time stamped attribute table.
Use t.vect.db.select to print attribute values of the space time vector dataset to stdout.
t.vect.observe.strds input=precip_30ynormals_3d strds=tempmean_monthly \
                     output=precip_stations vect=precip_stations_monthly \
                     columns=month
t.info precip_stations type=stvds
 +-------------------- Space Time Vector Dataset -----------------------------+
 +-------------------- Basic information -------------------------------------+
 | Id: ........................ precip_stations@climate_2009_2012
 | Name: ...................... precip_stations
 | Mapset: .................... climate_2009_2012
 | Creator: ................... lucadelu
 | Temporal type: ............. absolute
 | Creation time: ............. 2014-12-02 00:42:39.187615
 | Modification time:.......... 2014-12-02 00:42:55.215169
 | Semantic type:.............. mean
 +-------------------- Absolute time -----------------------------------------+
 | Start time:................. 2009-01-01 00:00:00
 | End time:................... 2013-01-01 00:00:00
 | Granularity:................ 1 month
 | Temporal type of maps:...... interval
 +-------------------- Spatial extent ----------------------------------------+
 | North:...................... 306221.830194
 | South:...................... 27606.895351
 | East:.. .................... 917004.829165
 | West:....................... 151768.568246
 | Top:........................ 1615.44
 | Bottom:..................... 2.4384
 +-------------------- Metadata information ----------------------------------+
 | Vector register table:...... vector_map_register_be074525097c4088997c9a1979f17065
 | Number of points ........... 6664
 | Number of lines ............ 0
 | Number of boundaries ....... 0
 | Number of centroids ........ 0
 | Number of faces ............ 0
 | Number of kernels .......... 0
 | Number of primitives ....... 6664
 | Number of nodes ............ 0
 | Number of areas ............ 0
 | Number of islands .......... 0
 | Number of holes ............ 0
 | Number of volumes .......... 0
 | Number of registered maps:.. 49
 | Title:
 | Observaion of space time raster dataset(s) tempmean_monthly
 | Description:
 | Observation of space time raster dataset(s) tempmean_monthly with vector map precip_30ynormals_3d
 | Command history:
 | # 2014-12-02 00:42:39
 | t.vect.observe.strds input="precip_30ynormals_3d"
 |     strds="tempmean_monthly" output="precip_stations"
 |     vect="precip_stations_monthly" columns="month"
v.info precip_stations_monthly
 | Mapset:          climate_2009_2012                                         |
 | Location:        nc_spm_temporal_workshop                                  |
 | Database:        /grassdata                                                |
 | Title:           North Carolina 30 year precipitation normals (3D)         |
 | Map scale:       1:1                                                       |
 | Name of creator: neteler                                                   |
 | Organization:                                                              |
 | Source date:     Wed May  9 14:32:39 2007                                  |
 | Timestamp (first layer): none                                              |
 | Map format:      native                                                    |
 |   Type of map: vector (level: 2)                                           |
 |   Number of points:       136             Number of centroids:  0          |
 |   Number of lines:        0               Number of boundaries: 0          |
 |   Number of areas:        0               Number of islands:    0          |
 |   Number of faces:        0               Number of kernels:    0          |
 |   Number of volumes:      0               Number of holes:      0          |
 |   Map is 3D:              Yes                                              |
 |   Number of dblinks:      49                                               |
 |   Projection: Lambert Conformal Conic                                      |
 |               N:     306221.830194    S:      27606.895351                 |
 |               E:     917004.829165    W:     151768.568246                 |
 |               B:            2.4384    T:           1615.44                 |
 |   Digitization threshold: 0                                                |
 |   Comment:        |
Last changed: $Date$
Available at: t.vect.observe.strds source code (history)
Main index | Temporal index | Topics index | Keywords index | Graphical index | Full index
© 2003-2019 GRASS Development Team, GRASS GIS 7.4.5dev Reference Manual
