Note: A new GRASS GIS stable version has been released: GRASS GIS 7.8, available here.
Updated manual page: here
| g.access | Controls access to the current mapset for other users on the system. |
| g.copy | Copies available data files in the current mapset search path to the user's current mapset. |
| g.dirseps | Internal GRASS utility for converting directory separator characters. |
| g.filename | Prints GRASS data base file names. |
| g.findetc | Searches for GRASS support files. |
| g.findfile | Searches for GRASS data base files and sets variables for the shell. |
| g.list | Lists available GRASS data base files of the user-specified data type optionally using the search pattern. |
| g.remove | Removes data base element files from the user's current mapset using the search pattern. |
| g.rename | Renames data base element files in the user's current mapset. |
| i.group | Creates, edits, and lists groups of imagery data. |
| i.target | Targets an imagery group to a GRASS location and mapset. |
| r.compress | Compresses and decompresses raster maps. |
| t.create | Creates a space time dataset. |
| t.list | Lists space time datasets and maps registered in the temporal database. |
| t.rast.list | Lists registered maps of a space time raster dataset. |
| t.rast3d.list | Lists registered maps of a space time raster3d dataset. |
| t.register | Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset. |
| t.remove | Removes space time datasets from temporal database. |
| t.rename | Renames a space time dataset |
| t.unregister | Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset. |
| t.vect.list | Lists registered maps of a space time vector dataset. |
See also the corresponding keyword map management for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2019 GRASS Development Team, GRASS GIS 7.4.5dev Reference Manual
