GRASS logo
Topic: import
db.in.ogr Imports attribute tables in various formats.
i.in.spotvgt Imports SPOT VGT NDVI data into a raster map.
r.external Links GDAL supported raster data as a pseudo GRASS raster map.
r.import Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly.
r.in.ascii Converts a GRASS ASCII raster file to binary raster map.
r.in.aster Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp.
r.in.bin Import a binary raster file into a GRASS raster map layer.
r.in.gdal Imports raster data into a GRASS raster map using GDAL library.
r.in.gridatb Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map.
r.in.lidar Creates a raster map from LAS LiDAR points using univariate statistics.
r.in.mat Imports a binary MAT-File(v4) to a GRASS raster.
r.in.png Imports non-georeferenced PNG format image.
r.in.poly Creates raster maps from ASCII polygon/line/point data files.
r.in.srtm Imports SRTM HGT files into raster map.
r.in.wms Downloads and imports data from WMS/WMTS/NASA OnEarth server.
r.in.xyz Creates a raster map from an assemblage of many coordinates using univariate statistics.
r.unpack Imports a GRASS GIS specific raster archive file (packed with r.pack) as a raster map
r3.in.ascii Converts a 3D ASCII raster text file into a (binary) 3D raster map.
r3.in.bin Imports a binary raster file into a GRASS 3D raster map.
r3.in.lidar Creates a 3D raster map from LAS LiDAR points using univariate statistics.
r3.in.v5d Import 3-dimensional Vis5D files.
r3.in.xyz Create a 3D raster map from an assemblage of many coordinates using univariate statistics
t.rast.import Imports space time raster dataset.
t.vect.import Imports a space time vector dataset from a GRASS GIS specific archive file.
v.external Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table.
v.import Imports vector data into a GRASS vector map using OGR library and reprojects on the fly.
v.in.ascii Creates a vector map from an ASCII points file or ASCII vector file.
v.in.db Creates new vector (points) map from database table containing coordinates.
v.in.dxf Converts file in DXF format to GRASS vector map.
v.in.e00 Imports E00 file into a vector map.
v.in.geonames Imports geonames.org country files into a vector points map.
v.in.lidar Converts LAS LiDAR point clouds to a GRASS vector map with libLAS.
v.in.lines Imports ASCII x,y[,z] coordinates as a series of lines.
v.in.mapgen Imports Mapgen or Matlab-ASCII vector maps into GRASS.
v.in.ogr Imports vector data into a GRASS vector map using OGR library.
v.in.wfs Imports GetFeature from a WFS server.
v.unpack Imports a GRASS GIS specific vector archive file (packed with v.pack) as a vector map
See also the corresponding keyword import for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2018 GRASS Development Team, GRASS GIS 7.5.svn Reference Manual
