Note: A new GRASS GIS stable version has been released: GRASS GIS 7.8, available here.
Updated manual page: here
| option | answer | description | descriptions | gisprompt | key | key_desc | label | multiple | options | required | type |
| G_OPT_DB_SQL | Example: select * from towns where population > 10000 | sql | sql_query | SQL SELECT statement | NO | TYPE_STRING | |||||
| G_OPT_DB_WHERE | Example: income < 1000 and population >= 10000 | old,sql_query,sql_query | where | sql_query | WHERE conditions of SQL statement without 'where' keyword | NO | TYPE_STRING | ||||
| G_OPT_DB_TABLE | Name of attribute table | old,dbtable,dbtable | table | name | NO | NO | TYPE_STRING | ||||
| G_OPT_DB_DRIVER | Name of database driver | old,dbdriver,dbdriver | driver | name | NO | NO | TYPE_STRING | ||||
| G_OPT_DB_DATABASE | Name of database | old,dbname,dbname | database | name | NO | NO | TYPE_STRING | ||||
| G_OPT_DB_SCHEMA | Do not use this option if schemas are not supported by driver/database server | schema | name | Database schema | NO | NO | TYPE_STRING | ||||
| G_OPT_DB_COLUMN | Name of attribute column | old,dbcolumn,dbcolumn | column | name | NO | NO | TYPE_STRING | ||||
| G_OPT_DB_COLUMNS | Name of attribute column(s | old,dbcolumn,dbcolumn | columns | name | YES | NO | TYPE_STRING | ||||
| G_OPT_DB_KEYCOLUMN | GV_KEY_COLUMN | Must refer to an integer column | key | name | Name of key column | NO | NO | TYPE_STRING | |||
| G_OPT_I_GROUP | Name of input imagery group | old,group,group | group | name | YES | TYPE_STRING | |||||
| G_OPT_I_SUBGROUP | Name of input imagery subgroup | old,subgroup,subgroup | subgroup | name | YES | TYPE_STRING | |||||
| G_OPT_R_INPUT | Name of input raster map | old,cell,raster | input | name | YES | TYPE_STRING | |||||
| G_OPT_R_INPUTS | Name of input raster map(s | old,cell,raster | input | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R_OUTPUT | Name for output raster map | new,cell,raster | output | name | YES | TYPE_STRING | |||||
| G_OPT_R_OUTPUTS | Name for output raster map(s | new,cell,raster | output | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R_MAP | Name of raster map | old,cell,raster | map | name | YES | TYPE_STRING | |||||
| G_OPT_R_MAPS | Name of raster map(s | old,cell,raster | map | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R_BASE | Name of base raster map | old,cell,raster | base | name | YES | TYPE_STRING | |||||
| G_OPT_R_COVER | Name of cover raster map | old,cell,raster | cover | name | YES | TYPE_STRING | |||||
| G_OPT_R_ELEV | Name of input elevation raster map | old,cell,raster | elevation | name | YES | TYPE_STRING | |||||
| G_OPT_R_ELEVS | Name of input elevation raster map(s | old,cell,raster | elevation | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R_TYPE | Storage type for resultant raster map | type | Type of raster map to be created | NO | CELL,FCELL,DCELL | YES | TYPE_STRING | ||||
| G_OPT_R_INTERP_TYPE | Sampling interpolation method | method | nearest,bilinear,bicubic | NO | TYPE_STRING | ||||||
| G_OPT_R_BASENAME_INPUT | Name of input basename raster map(s | old,cell,raster | input | basename | NO | YES | TYPE_STRING | ||||
| G_OPT_R_BASENAME_OUTPUT | Name for output basename raster map(s | new,cell,raster | output | basename | NO | YES | TYPE_STRING | ||||
| G_OPT_R3_INPUT | Name of input 3D raster map | old,grid3,raster_3d | input | name | YES | TYPE_STRING | |||||
| G_OPT_R3_INPUTS | Name of input 3D raster map(s | old,grid3,raster_3d | input | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R3_OUTPUT | Name for output 3D raster map | new,grid3,raster_3d | output | name | YES | TYPE_STRING | |||||
| G_OPT_R3_MAP | Name of 3D raster map | old,grid3,raster_3d | map | name | YES | TYPE_STRING | |||||
| G_OPT_R3_MAPS | Name of 3D raster map(s | old,grid3,raster_3d | map | name | YES | YES | TYPE_STRING | ||||
| G_OPT_R3_TYPE | default | Data type used in the output raster3d map | type | NO | default,double,float | NO | TYPE_STRING | ||||
| G_OPT_R3_PRECISION | default | Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default | precision | NO | NO | TYPE_STRING | |||||
| G_OPT_R3_COMPRESSION | default | The compression method used in the output raster3d map | compression | NO | default,zip,none | NO | TYPE_STRING | ||||
| G_OPT_R3_TILE_DIMENSION | default | The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8 | tiledimension | XxYxZ | NO | NO | TYPE_STRING | ||||
| G_OPT_V_INPUT | Or data source for direct OGR access | old,vector,vector | input | name | Name of input vector map | YES | TYPE_STRING | ||||
| G_OPT_V_INPUTS | Or data source(s) for direct OGR access | old,vector,vector | input | name | Name of input vector map(s | YES | YES | TYPE_STRING | |||
| G_OPT_V_OUTPUT | Name for output vector map | new,vector,vector | output | name | YES | TYPE_STRING | |||||
| G_OPT_V_MAP | Or data source for direct OGR access | old,vector,vector | map | name | Name of vector map | YES | TYPE_STRING | ||||
| G_OPT_V_MAPS | Name of vector map(s | old,vector,vector | map | name | YES | YES | TYPE_STRING | ||||
| G_OPT_V_TYPE | point,line,boundary,centroid,area | Input feature type | type | YES | point,line,boundary,centroid,area | NO | TYPE_STRING | ||||
| G_OPT_V3_TYPE | point,line,boundary,centroid,area,face,kernel | Input feature type | type | YES | point,line,boundary,centroid,area,face,kernel | NO | TYPE_STRING | ||||
| G_OPT_V_FIELD | 1 | Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name. | old,layer,layer | layer | Layer number or name | NO | TYPE_STRING | ||||
| G_OPT_V_FIELD_ALL | -1 | A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name. | old,layer_all,layer | layer | Layer number or name ('-1' for all layers | NO | TYPE_STRING | ||||
| G_OPT_V_CAT | Category value | old,cat,cats | cat | NO | TYPE_INTEGER | ||||||
| G_OPT_V_CATS | Example: 1,3,7-9,13 | old,cats,cats | cats | range | Category values | NO | TYPE_STRING | ||||
| G_OPT_V_ID | Feature id | id | NO | TYPE_INTEGER | |||||||
| G_OPT_V_IDS | Example: 1,3,7-9,13 | ids | range | Feature ids | NO | TYPE_STRING | |||||
| G_OPT_F_INPUT | Name of input file | old,file,file | input | name | YES | TYPE_STRING | |||||
| G_OPT_F_BIN_INPUT | Name of input file | old,bin,file | input | name | YES | TYPE_STRING | |||||
| G_OPT_F_OUTPUT | Name for output file | new,file,file | output | name | YES | TYPE_STRING | |||||
| G_OPT_F_SEP | pipe | Special characters: pipe, comma, space, tab, newline | old,separator,separator | separator | character | Field separator | NO | TYPE_STRING | |||
| G_OPT_C | DEFAULT_FG_COLOR | Either a standard color name or R:G:B triplet | old,color,color | color | name | Color | NO | TYPE_STRING | |||
| G_OPT_CN | DEFAULT_FG_COLOR | Either a standard color name, R:G:B triplet, or \none\ | old,color_none,color | color | name | Color | NO | TYPE_STRING | |||
| G_OPT_M_DIR | Name of input directory | old,dir,dir | input | name | YES | TYPE_STRING | |||||
| G_OPT_M_UNITS | Units | units | NO | miles,feet,meters,kilometers,acres,hectares | NO | TYPE_STRING | |||||
| G_OPT_M_DATATYPE | Data type(s | type | datatype | YES | YES | TYPE_STRING | |||||
| G_OPT_M_MAPSET | '.' for current mapset | old,mapset,mapset | mapset | name | Name of mapset (default: current search path | NO | NO | TYPE_STRING | |||
| G_OPT_M_LOCATION | Location name (not location path | old,location,location | location | name | Location name | NO | NO | TYPE_STRING | |||
| G_OPT_M_DBASE | Default: path to the current GRASS GIS database | old,dbase,dbase | dbase | path | GRASS GIS database directory | NO | NO | TYPE_STRING | |||
| G_OPT_M_COORDS | Coordinates | old,coords,coords | coordinates | east,north | NO | NO | TYPE_DOUBLE | ||||
| G_OPT_M_COLR | Name of color table | G_color_rules_description_type( | old,colortable,colortable | color | style | G_color_rules_options( | NO | TYPE_STRING | |||
| G_OPT_M_NULL_VALUE | String representing NULL value | null_value | string | NO | NO | TYPE_STRING | |||||
| G_OPT_M_REGION | Name of saved region | old,windows,region | region | name | NO | TYPE_STRING | |||||
| G_OPT_STDS_INPUT | Name of the input space time dataset | old,stds,stds | input | name | YES | TYPE_STRING | |||||
| G_OPT_STDS_INPUTS | Name of the input space time datasets | old,stds,stds | inputs | name | YES | YES | TYPE_STRING | ||||
| G_OPT_STDS_OUTPUT | Name of the output space time dataset | new,stds,stds | output | name | YES | TYPE_STRING | |||||
| G_OPT_STRDS_INPUT | Name of the input space time raster dataset | old,strds,strds | input | name | YES | TYPE_STRING | |||||
| G_OPT_STRDS_INPUTS | Name of the input space time raster datasets | old,strds,strds | inputs | name | YES | YES | TYPE_STRING | ||||
| G_OPT_STRDS_OUTPUT | Name of the output space time raster dataset | new,strds,strds | output | name | YES | TYPE_STRING | |||||
| G_OPT_STVDS_INPUT | Name of the input space time vector dataset | old,stvds,stvds | input | name | YES | TYPE_STRING | |||||
| G_OPT_STVDS_INPUTS | Name of the input space time vector datasets | old,stvds,stvds | inputs | name | YES | YES | TYPE_STRING | ||||
| G_OPT_STVDS_OUTPUT | Name of the output space time vector dataset | new,stvds,stvds | output | name | YES | TYPE_STRING | |||||
| G_OPT_STR3DS_INPUT | Name of the input space time raster3d dataset | old,str3ds,str3ds | input | name | YES | TYPE_STRING | |||||
| G_OPT_STR3DS_INPUTS | Name of the input space time raster3d datasets | old,str3ds,str3ds | inputs | name | YES | YES | TYPE_STRING | ||||
| G_OPT_STR3DS_OUTPUT | Name of the output space time raster3d dataset | new,str3ds,str3ds | output | name | YES | TYPE_STRING | |||||
| G_OPT_STDS_TYPE | strds | Type of the input space time dataset | type | name | strds,stvds,str3ds | NO | TYPE_STRING | ||||
| G_OPT_MAP_INPUT | Name of the input map | old,map,map | map | name | YES | TYPE_STRING | |||||
| G_OPT_MAP_INPUTS | Name of the input maps | old,map,map | maps | name | YES | YES | TYPE_STRING | ||||
| G_OPT_MAP_TYPE | raster | Type of the input map | type | name | raster,vector,raster_3d | NO | TYPE_STRING | ||||
| G_OPT_T_TYPE | absolute | The temporal type of the space time dataset | temporaltype | name | absolute,relative | NO | TYPE_STRING | ||||
| G_OPT_T_WHERE | Example: start_time > '2001-01-01 12:30:00' | where | sql_query | WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework | NO | TYPE_STRING | |||||
| G_OPT_T_SAMPLE | start | The method to be used for sampling the input dataset | sampling | name | YES | start,during,overlap,contain,equal,follows,precedes | NO | TYPE_STRING |
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2020 GRASS Development Team, GRASS GIS 7.6.2dev Reference Manual
