GRASS logo
MySQL DATABASE DRIVER
Table of contents
MySQL database driver enables GRASS to store vector attributes in MySQL server.
Because vector attribute tables are created automatically when a new vector is written and the name of the table is the same as the name of the vector it is good practice to create a new database for each GRASS mapset.
Creating a MySQL database
A new database is created within MySQL:
mysql> CREATE DATABASE mydb;
See the MySQL manual for details.
Driver and database name
GRASS modules require 2 parameters to connect to a database. Those parameters are 'driver' and 'database'. For MySQL driver the parameter 'driver' should be set to value 'mysql'. The parameter 'database' can be given in two formats: Examples of connection parameters:
  db.connect driver=mysql database=mytest
  db.connect driver=mysql database='dbname=mytest,host=test.grass.org'
Data types
GRASS supports almost all MySQL data types with following limitations:
Indexes
GRASS modules automatically create index on key column of vector attributes table. The index on key column is important for performance of modules which update the attribute table, for example v.to.db, v.distance and v.what.rast.
Privileges
Because MySQL does not support groups of users and because only MySQL 'root' can grant privileges to other users GRASS cannot automatically grant select privileges on created tables to group of users.
If you want to give privilege to read data from your mapset to other users you have to ask your MySQL server administrator to grant select privilege to them on the MySQL database used for that mapset. For example, to allow everybody to read data in from your database 'mydb':
shell> mysql --user=root mysql
mysql> GRANT SELECT ON mydb.* TO ''@'%';
Schemas
Because MySQL does not support database schemas the parameter 'schema' of module db.connect should never be set to any value. If you set that parameter for MySQL driver GRASS will try to write tables to the specified schema which will result in errors.
Groups
MySQL does not support user groups. Any settings specified by 'group' parameter of module db.connect are ignored by GRASS for MySQL driver.
Troubleshooting: SQL syntax error
Attempting to use a reserved SQL word as column or table name will result in a "SQL syntax" error. The list of reserved words for MySQL can be found in the MySQL manual.
SEE ALSO
db.connect, SQL support in GRASS GIS
Credits
Development of the driver was sponsored by Faunalia (Italy) as part of a project for ATAC.
AUTHOR
Radim Blazek
Last changed: $Date$
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2019 GRASS Development Team, GRASS GIS 7.8.dev Reference Manual
