Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
r.describe | Prints terse list of category values found in a raster map layer. |
r.info | Outputs basic information about a raster map. |
r.region | Sets the boundary definitions for a raster map. |
r.support | Allows creation and/or modification of raster map layer support files. |
r.timestamp | Modifies a timestamp for a raster map. |
r3.info | Outputs basic information about a user-specified 3D raster map layer. |
r3.support | Allows creation and/or modification of 3D raster map layer support files. |
r3.timestamp | Modifies a timestamp for a 3D raster map. |
t.downgrade | Downgrades the version of a space time dataset (TGRASS DB). |
t.info | Lists information about space time datasets and maps. |
t.select | Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra. |
t.support | Modifies the metadata of a space time dataset. |
v.info | Outputs basic information about a vector map. |
v.support | Updates vector map metadata. |
v.timestamp | Modifies a timestamp for a vector map. |
See also the corresponding keyword metadata for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 7.8.9dev Reference Manual
