Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
| d.where | Identifies the geographic coordinates associated with point locations given in display coordinates. |
| r.random.cells | Generates random cell values with spatial dependence. |
| r.random | Creates a raster map layer and vector point map containing randomly located points. |
| t.rast.what | Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts |
| t.sample | Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout. |
| t.vect.observe.strds | Observes specific locations in a space time raster dataset over a period of time using vector points. |
| t.vect.what.strds | Stores raster map values at spatial and temporal positions of vector points as vector attributes. |
| v.random | Generates random 2D/3D vector points. |
| v.sample | Samples a raster map at vector point locations. |
| v.what.rast | Uploads raster values at positions of vector points to the table. |
| v.what.rast3 | Uploads 3D raster values at positions of vector points to the table. |
| v.what.vect | Uploads vector values at positions of vector points to the table. |
See also the corresponding keyword sampling for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 7.8.9dev Reference Manual
