NAME
v.select - Selects features from vector map (A) by features from other vector map (B).
KEYWORDS
vector,
geometry,
spatial query
SYNOPSIS
v.select
v.select --help
v.select [-tcr] ainput=name [alayer=string] [atype=string[,string,...]] binput=name [blayer=string] [btype=string[,string,...]] output=name operator=string [relate=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -t
- Do not create attribute table
- -c
- Do not skip features without category
- -r
- Reverse selection
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- ainput=name [required]
- Name of input vector map
- Input vector map from which to select features (A)
- alayer=string
- Layer number (vector map A)
- Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
- Default: 1
- atype=string[,string,...]
- Feature type (vector map A)
- Input feature type
- Options: point, line, boundary, centroid, area
- Default: point,line,area
- binput=name [required]
- Query vector map (B)
- blayer=string
- Layer number (vector map B)
- Default: 1
- btype=string[,string,...]
- Feature type (vector map B)
- output=name [required]
- Name for output vector map
- operator=string [required]
- Operator defines required relation between features
- A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.
- Options: overlap, equals, disjoint, intersects, touches, crosses, within, contains, overlaps, relate
- Default: overlap
- overlap: features partially or completely overlap
- equals: features are spatially equals (using GEOS)
- disjoint: features do not spatially intersect (using GEOS)
- intersects: features spatially intersect (using GEOS)
- touches: features spatially touches (using GEOS)
- crosses: features spatially crosses (using GEOS)
- within: feature A is completely inside feature B (using GEOS)
- contains: feature B is completely inside feature A (using GEOS)
- overlaps: features spatially overlap (using GEOS)
- relate: feature A is spatially related to feature B (using GEOS, requires 'relate' option)
- relate=string
- Intersection Matrix Pattern used for 'relate' operator
v.select allows the user to select features from a vector
map by features from another one.
Supported operators (without GEOS; using GRASS' own algorithm):
- overlap - features partially or completely overlap (GEOS equivalent: intersects)
Supported operators (internally using
GEOS - Geometry Engine, Open Source):
- equals - features are spatially equals
- disjoint - features do not spatially intersect
- intersects - features spatially intersect (equivalent to native 'overlap')
- touches - features spatially touches
- crosses - features spatially crosses
- within - feature A is completely inside feature B
- contains - feature B is completely inside feature A
- overlaps - features spatially overlap
- relate - feature A is spatially related to feature B
Only features with category numbers will be considered. If required
the
v.category module can be
used to add them. Typically boundaries do not need to be given a
category number, as an area's attributes are inherited from the
centroid. Typically points, lines, and centroids will always want to
have a cat number. E.g. take a road which separates two farms. It is
ambiguous as to which farm an attribute that is attached to the road
belongs to. The boundary only needs a cat number if it will hold its
own attributes, such as road name or pavement form. A centroid in each
paddock holds the information with respect to ownership, area, etc.
Preparation of example data (North Carolina sample dataset):
# Create an grid for overlaying to ZIP code vector map
v.mkgrid map=boxgrid grid=10,10 position=coor \
coordinates=583600,201500 box=5000,5000
# set region to ZIP codes and boxgrid vector maps
g.region vector=zipcodes_wake,boxgrid -p res=100 -a
# enlarge region a bit for "white border" around map in monitor
g.region n=n+1000 s=s-1000 w=w-1000 e=e+1000 -p
d.mon wx0
Select grid boxes (North Carolina sample dataset):
d.vect map=zipcodes_wake fill_color=0:128:0
d.vect map=boxgrid fill_color=85:130:176
v.select ainput=boxgrid binput=zipcodes_wake output=v_select_OVERLAP operator=overlap
d.vect map=v_select_OVERLAP
d.vect map=zipcodes_wake type=boundary color=255:255:50
![v.select with OVERLAP operator](v_select_op_overlap.png)
v.select with OVERLAP operator: selected grid boxes shown in yellow (using GRASS method)
v.select ainput=boxgrid binput=zipcodes_wake output=v_select_OVERLAPS operator=overlaps
d.vect map=v_select_OVERLAPS
![v.select with OVERLAPS operator](v_select_op_overlaps.png)
v.select with OVERLAPS operator: selected grid boxes shown in yellow (using GEOS method)
v.select ainput=boxgrid binput=zipcodes_wake output=v_select_DISJOINT operator=disjoint
d.vect map=v_select_DISJOINT
![v.select with DISJOINT operator](v_select_op_disjoint.png)
v.select with DISJOINT operator: selected grid boxes shown in yellow
Select zipcode polygon (North Carolina sample dataset):
v.extract input=zipcodes_wake where=ZIPCODE_ID=35 output=zipcodeID35
v.select ainput=zipcodes_wake binput=zipcodeID35 output=v_select_EQUALS operator=equals
d.vect map=v_select_EQUALS
![v.select with EQUALS operator](v_select_op_equals.png)
v.select with EQUALS operator: selected grid boxes shown in yellow
Select zipcode polygons (North Carolina sample dataset):
v.select ainput=zipcodes_wake binput=boxgrid output=v_select_INTERSECTS operator=intersects
d.vect map=v_select_INTERSECTS
d.vect map=boxgrid type=boundary color=255:255:50
![v.select with INTERSECTS operator](v_select_op_intersects.png)
v.select with INTERSECTS operator: selected grid boxes shown in yellow
Select polygons (North Carolina sample dataset):
d.vect map=zipcodeID35 fill_color=85:130:176
v.select ainput=zipcodes_wake binput=zipcodeID35 output=v_select_TOUCHES operator=touches
d.vect map=v_select_TOUCHES
![v.select with TOUCHES operator](v_select_op_touches.png)
v.select with TOUCHES operator: selected polygons shown in yellow (blue: input polygon)
Select zipcode polygons by lines (North Carolina sample dataset):
d.vect map=busroute1 color=200:27:27 width=3
v.select ainput=zipcodes_wake binput=busroute1 output=v_select_CROSSES operator=crosses
d.vect map=v_select_CROSSES
![v.select with CROSSES operator](v_select_op_crosses.png)
v.select with CROSSES operator: selected polygons shown in yellow (red: input lines)
d.vect map=boundary_county fill_color=85:130:176
v.select ainput=zipcodes_wake binput=boundary_county output=v_select_WITHIN operator=within
d.vect map=v_select_WITHIN
![v.select with WITHIN operator](v_select_op_within.png)
v.select with WITHIN operator: selected polygons shown in yellow (blue: input polygons)
CONTAINS with polygons
v.select ainput=zipcodes_wake binput=zipcodeID35 \
output=v_select_CONTAINS_pol operator=contains
d.vect map=v_select_CONTAINS
![v.select with CONTAINS operator](v_select_op_contains_pol.png)
v.select with CONTAINS operator: selected polygon shown in yellow (blue: input polygon, not visible)
CONTAINS with points
d.vect map=hospitals fill_color=195:31:31 icon=basic/cross3 size=10
v.select ainput=zipcodes_wake binput=hospitals \
output=v_select_CONTAINS_pnts operator=contains
d.vect map=v_select_CONTAINS_pnts
![v.select with CONTAINS operator](v_select_op_contains_pnts.png)
v.select with CONTAINS operator: selected polygons shown in yellow (red: input points)
This operator additionally requires the
relate parameter (in other
GIS called 'ST_Relate').
This operator allows calculating the
Dimensionally Extended nine-Intersection Model (DE-9IM).
In the following one example: Select polygon with 'TOUCHES' operator
v.select ainput=zipcodeID35 binput=zipcodes_wake \
output=v_select_TOUCHES_relate operator=relate relate='T********'
The result of
relate='T********' is the same as seen
above in the example 'TOUCHES'.
See the
DE-9IM page
for related operators and their definition.
Extract fire stations (points) falling into urban area (polygon) - North Carolina
data set (point in polygon test):
v.select ainput=firestations binput=urbanarea output=urban_firestations \
operator=overlap
Extract railroad lines from zip code map overlapping with the urban area
(line in polygon test):
v.select ainput=railroads binput=urbanarea \
output=railroads_in_urbanarea operator=overlap
Extract those areas from zip code map which overlap with railroads
(polygon on line test):
# first add a tiny buffer around railroad lines:
v.buffer input=railroads output=railroads_buf20m \
distance=20
v.select ainput=zipcodes_wake binput=railroads_buf20m \
output=zipcodes_wake_railroads operator=overlap
v.category,
v.clip,
v.overlay,
v.extract
GRASS SQL interface
Radim Blazek
GEOS support by Martin Landa, Czech Technical University in Prague, Czech Republic
ZIP code examples by Carol X. Garzon-Lopez, Trento, Italy
SOURCE CODE
Available at:
v.select source code
(history)
Latest change: Monday Nov 18 20:15:32 2019 in commit: 1a1d107e4f6e1b846f9841c2c6fabf015c5f720d
Main index |
Vector index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
