GRASS logo
NAME
g.parser - Provides full parser support for GRASS scripts.
Table of contents
KEYWORDS
general, support, scripts
SYNOPSIS
g.parser --help
g.parser [-s] [-t] [-n] filename [argument,...]
Flags:
-t
Print strings for translation
-s
Write option values to standard output instead of reinvoking script
-n
Write option values to standard output separated by null character
DESCRIPTION
The g.parser module provides full parser support for GRASS scripts, including an auto-generated GUI interface, help page template, and command line option checking. In this way a simple script can very quickly be made into a full-fledged GRASS module.
OPTIONS
Unless the -s or -n switch is used, the arguments are stored in environment variables for use in your scripts. These variables are named "GIS_FLAG_<NAME>" for flags and "GIS_OPT_<NAME>" for options. The names of variables are converted to upper case. For example if an option with key input was defined in the script header, the value will be available in variable GIS_OPT_INPUT and the value of flag with key f will be available in variable GIS_FLAG_F.
For flags, the value will be "1" if the flag was given, and "0" otherwise.
If the -s or -n switch is used, the options and flags are written to standard output in the form opt_<name>=<value> and flag_<name>=<value>, preceded by the string @ARGS_PARSED@. If this string doesn't appear as the first line of standard output, it indicates that the script was invoked with a switch such as --html-description. In this case, the data written by g.parser to standard output should be copied to the script's standard output verbatim. If the -s switch is used, the options and flags are separated by newlines. If the -n switch is used, the options and flags are separated by null characters.
Typical header definitions are as follows:
#%module
#% description: g.parser test script
#%end
#%flag
#% key: f
#% description: A flag
#%end
#%option
#% key: raster
#% type: string
#% gisprompt: old,cell,raster
#% description: Raster input map
#% required: yes
#%end
With {NULL} it is possible to suppress a predefined description or label.
The parsers allows using predefined standardized options and flags, see the list of options and flags in the programmer manual. Eg. the option
#%option
#% key: raster
#% type: string
#% required: yes
#%end
can be easily defined as
#%option G_OPT_R_MAP
#% key: raster
#%end
The parser allows defining predefined rules for used options. The syntax of the rules section is following:
#%rules
#% exclusive: capfile_output, capfile
#%end
The parser also allows defining "OR" conditions, e.g. requiring raster OR vector (for details, see below), e.g.for options:
#%rules
#% required: raster, vector
#%end
and e.g., for flags:
#%rules
#% required: -i,-d,-c
#%end
NOTES
An option can be instructed to allow multiple inputs by adding the following line:
#% multiple: yes
While this will only directly change the Usage section of the help screen, the option's environmental string may be easily parsed from within a script. For example, individual comma separated identities for an option named "input" can be parsed with the following Bash shell code:
IFS=,
for opt in $GIS_OPT_INPUT ; do
    ... "$opt"
done
A "guisection" field may be added to each option and flag to specify that the options should appear in multiple tabs in the auto-generated GUI. Any options without a guisection field go into the "Required" or "Options" tab. For example:
#% guisection: tabname
would put that option in a tab named tabname.
A "key_desc" field may be added to each option to specify the text that appears in the module's usage help section. For example:
#% key_desc: filename
added to an input option would create the usage summary [input=filename].
If a script is run with --o, the parser will set GRASS_OVERWRITE=1, which has the same effect as passing --o to every module which is run from the script. Similarly, passing --q or --v will set GRASS_VERBOSE to 0 or 3 respectively, which has the same effect as passing --q or --v to every module which is run from the script. Rather than checking whether --o, --q or --v were used, you should be checking GRASS_OVERWRITE and/or GRASS_VERBOSE instead. If those variables are set, the script should behave the same way regardless of whether they were set by --o, --q or --v being passed to the script or set by other means.
Conditional parameters
Marking an option as "required" will result in the parser raising a fatal error if the option is not given, with one exception: if a flag has the suppress_required option, and that flag is given, all requirements are ignored. This feature is intended for flags which abandon "normal operation" for the module; e.g. r.in.gdal's -f flag (list supported formats) uses it.
But in general, an option cannot be marked as required if it is optional except for the special case of a suppress_required flag. The parser has the ability to specify option relationships.
For C, the relevant functions are those in lib/gis/parser_dependencies.c.
For scripts, relationships are specified using a "rules" section, e.g.
#%rules
#% required: altitude,elevation
#%end
specifies that at least one of those options must be given. Both options and flags can be specified (a leading "-" denotes a flag). The available rule types are:
AUTOMATED SCRIPT CREATION
The flag --script added to a GRASS command, generates shell output. To write out a g.parser boilerplate for easy prototyping of Python scripts, the flag --script can be added to any GRASS command. Example:
v.in.db --script
Help page template (HTML)
The flag --html-description added to a GRASS command generates a related help page template in HTML. Example:
v.in.db --html-description
GUI window parser (XML)
The flag --interface-description added to a GRASS command generates a related help page template in XML. Example:
v.in.db --interface-description
JSON
The flag --json added to a GRASS command with parameters mandatorily to be specified generates a module interface description in JSON. Example:
v.in.db driver=sqlite database=mysqlite.db table=pointsfile x=x y=y z=z key=idcol out=dtmpoints --json
  "module": "v.in.db",
  "id": "v.in.db_1804289383",
  "inputs":[
     {"param": "table", "value": "pointsfile"},
     {"param": "driver", "value": "sqlite"},
     {"param": "database", "value": "mysqlite.db"},
     {"param": "x", "value": "x"},
     {"param": "y", "value": "y"},
     {"param": "z", "value": "z"},
     {"param": "key", "value": "idcol"}
  "outputs":[
     {"param": "output", "value": "dtmpoints"}
Web Processing Service (WPS)
The flag --wps-process-description added to a GRASS command generates a Web Processing Service process description. Example:
v.in.db --wps-process-description
reStructuredText
The flag --rst-description added to a GRASS command generates module interface description in reStructuredText, a lightweight markup language. Example:
v.in.db --rst-description
reStructuredText is sometimes abbreviated as reST, ReST, or RST. The commonly used file extension is .rst. Don't be confused with Representational State Transfer (REST) technology.
TRANSLATION
g.parser provides some support for translating the options of scripts. If called with the -t switch before the script filename like this
g.parser -t somescriptfile
g.parser will print the text of the translatable options to standard output, one per line, and exit. This is for internal use within the build system to prepare GRASS scripts for translation.
EXAMPLES
All examples below autogenerate the graphical user interface when invoked without parameters of flags:
Autogenerated GUI window
To run properly, the script needs to be copied into a directory listed in $GRASS_ADDON_PATH environmental variable with the executable flag being set.
The script will provide a GUI (as above) and the following usage help text:
test.py|sh|pl --help
Description:
 g.parser test script (python)
Usage:
 test.sh [-f] raster=string vector=string [option1=string]
   [--verbose] [--quiet]
Flags:
  -f   A flag
 --v   Verbose module output
 --q   Quiet module output
Parameters:
   raster   Raster input map
   vector   Vector input map
  option1   An option
Example code for Python
#!/usr/bin/env python3
# g.parser demo script for python programming
#%module
#% description: g.parser test script (python)
#% keyword: keyword1
#% keyword: keyword2
#%end
#%flag
#% key: f
#%end
#% key: raster
#% required: yes
#%end
#%option G_OPT_V_MAP
#% key: vector
#%end
#%option
#% key: option1
#% type: string
#% description: An option
#% required: no
#%end
import os
import sys
import grass.script as gs
def main():
    flag_f = flags['f']
    option1 = options['option1']
    raster = options['raster']
    vector = options['vector']
    #### add your code here ####
    if flag_f:
        print "Flag -f set"
    else:
        print "Flag -f not set"
    # test if parameter present:
    if option1:
        print "Value of option1 option: '%s'" % option1
    print "Value of raster option: '%s'" % raster
    print "Value of vector option: '%s'" % vector
    #### end of your code ####
    return 0
if __name__ == "__main__":
    options, flags = gs.parser()
    sys.exit(main())
Example code for SHELL
#!/bin/sh
# g.parser demo script for shell programming
#%module
#% description: g.parser test script (shell)
#%end
#%flag
#% key: f
#%end
#% key: raster
#% required: yes
#%end
#% key: vector
#%end
#%option
#% key: option1
#% type: string
#% required: no
#%end
if [ -z "$GISBASE" ] ; then
    echo "You must be in GRASS GIS to run this program." 1>&2
    exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
    exec g.parser "$0" "$@"
fi
#### add your code below ####
echo ""
if [ $GIS_FLAG_F -eq 1 ] ; then
  g.message message="Flag -f set"
else
  g.message message="Flag -f not set"
fi
if [ -n "$GIS_OPT_OPTION1" ] ; then
    echo "Value of GIS_OPT_OPTION1: '$GIS_OPT_OPTION1'"
fi
g.message message="Value of GIS_OPT_option1: '$GIS_OPT_option1'"
g.message message="Value of GIS_OPT_raster: '$GIS_OPT_raster'"
g.message message="Value of GIS_OPT_vect: '$GIS_OPT_vector'"
Example code for Perl
#!/usr/bin/perl -w
use strict;
#%module
#%  description: g.parser test script (perl)
#%end
#%flag
#%  key: f
#%end
#% key: raster
#% required: yes
#%end
#% key: vector
#%end
#%option
#% key: option1
#% type: string
#% required: no
#%end
if ( !$ENV{'GISBASE'} ) {
    printf(STDERR  "You must be in GRASS GIS to run this program.\n");
    exit 1;
if( $ARGV[0] ne '@ARGS_PARSED@' ){
    my $arg = "";
    for (my $i=0; $i < @ARGV;$i++) {
        $arg .= " $ARGV[$i] ";
    system("$ENV{GISBASE}/bin/g.parser $0 $arg");
    exit;
print  "\n";
if ( $ENV{'GIS_FLAG_F'} eq "1" ){
   print "Flag -f set\n"
else {
   print "Flag -f not set\n"
printf ("Value of GIS_OPT_option1: '%s'\n", $ENV{'GIS_OPT_OPTION1'});
printf ("Value of GIS_OPT_raster: '%s'\n", $ENV{'GIS_OPT_RASTER'});
printf ("Value of GIS_OPT_vect: '%s'\n", $ENV{'GIS_OPT_VECTOR'});
Easy creation of a script
By using the --script flag with any GRASS GIS module (must be run in a GRASS GIS session) header, description, keywords, parameters, flags and a template main Python script section will be printed in the terminal which can be saved to a file and used for further script programming.
In this example, the module v.what.rast is used as an example. The output is shown below:
v.what.rast --script
# MODULE:       v.what.rast_wrapper
# AUTHOR(S):    username
# PURPOSE:      Wrapper for v.what.rast
# COPYRIGHT:    (C) 2017 by username, and the GRASS Development Team
#  This program is free software; you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation; either version 2 of the License, or
#  (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#%module
#% description: Uploads raster values at positions of vector points to the table.
#% keyword: vector, sampling, raster, position, querying, attribute table, surface information
#%end
#%flag
#% key: i
#% description: Interpolate values from the nearest four cells
#%end
#%flag
#% key: p
#% description: Print categories and values instead of updating the database
#%end
#%option
#% key: map
#% type: string
#% required: yes
#% multiple: no
#% key_desc: name
#% label: Name of vector points map for which to edit attributes
#% description: Or data source for direct OGR access
#% gisprompt: old,vector,vector
#%end
#%option
#% key: layer
#% type: string
#% required: no
#% multiple: no
#% label: Layer number or name
#% description: Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
#% answer: 1
#% gisprompt: old,layer,layer
#%end
#%option
#% key: type
#% type: string
#% required: no
#% multiple: yes
#% options: point,centroid
#% description: Input feature type
#% answer: point
#%end
#%option
#% key: raster
#% type: string
#% required: yes
#% multiple: no
#% key_desc: name
#% description: Name of existing raster map to be queried
#%end
#%option
#% key: column
#% type: string
#% required: no
#% multiple: no
#% key_desc: name
#% description: Name of attribute column to be updated with the query result
#% gisprompt: old,dbcolumn,dbcolumn
#%end
#%option
#% key: where
#% type: string
#% required: no
#% multiple: no
#% key_desc: sql_query
#% label: WHERE conditions of SQL statement without 'where' keyword
#% description: Example: income < 1000 and population >= 10000
#%end
import sys
def main():
    # put code here
    return 0
    sys.exit(main())
SEE ALSO
g.filename, g.findfile, g.tempfile
Overview table: Parser standard options
Submitting rules for Python
Related Wiki pages: Using GRASS GIS with other programming languages
AUTHOR
Glynn Clements
SOURCE CODE
Available at: g.parser source code (history)
Main index | General index | Topics index | Keywords index | Graphical index | Full index
© 2003-2020 GRASS Development Team, GRASS GIS 7.9.dev Reference Manual
