GRASS logo
NAME
r.surf.gauss - Generates a raster map using gaussian random number generator.
Mean and standard deviation of gaussian deviates can be expressed by the user.
KEYWORDS
raster, surface, random
SYNOPSIS
r.surf.gauss
r.surf.gauss --help
r.surf.gauss output=name [mean=float] [sigma=float] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
output=name [required]
Name for output raster map
mean=float
Distribution mean
Default: 0.0
sigma=float
Standard deviation
Default: 1.0
Table of contents
DESCRIPTION
r.surf.gauss produces a raster map of Gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a Gaussian random number generator. It is essentially the same as r.surf.random, but uses a Gaussian random number generator instead.
r.surf.gauss map histogram
Histogram of map generated with r.surf.gauss (mean=0, sigma=10)
EXAMPLE
g.region -p n=228500 s=215000 w=630000 e=645000 res=10
r.surf.gauss out=gauss mean=0 sigma=10
# check result
r.univar gauss
SEE ALSO
r.surf.contour, r.surf.fractal, r.surf.idw, r.surf.random, v.surf.rst
AUTHOR
Jo Wood, ASSIST's home
SOURCE CODE
Available at: r.surf.gauss source code (history)
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2020 GRASS Development Team, GRASS GIS 7.9.dev Reference Manual
