Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
| r.series | Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers. |
| t.rast.aggregate.ds | Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset. |
| t.rast.aggregate | Aggregates temporally the maps of a space time raster dataset by a user defined granularity. |
| t.rast.neighbors | Performs a neighborhood analysis for each map in a space time raster dataset. |
| t.rast.series | Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset. |
See also the corresponding keyword aggregation for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.0.3dev Reference Manual
