Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
| d.erase | Erases the contents of the active graphics display frame with user defined color. |
| d.frame | Manages display frames on the user's graphics monitor. |
| d.his | Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers. |
| d.info | Displays information about the active display monitor. |
| d.mon | Controls graphics display monitors from the command line. |
| d.rast | Displays user-specified raster map in the active graphics frame. |
| d.redraw | Redraws the content of currently selected monitor. |
| d.rgb | Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame. |
| d.vect | Displays user-specified vector map in the active graphics frame. |
| m.nviz.script | Creates fly-through script to run in NVIZ. |
| wxpyimgview | Views BMP images from the PNG driver. |
| ximgview | View BMP images from the PNG driver. |
See also the corresponding keyword graphics for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.0.3dev Reference Manual
