Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
| r.describe | Prints terse list of category values found in a raster map layer. |
| r.info | Outputs basic information about a raster map. |
| r.region | Sets the boundary definitions for a raster map. |
| r.support | Allows creation and/or modification of raster map layer support files. |
| r.timestamp | Modifies a timestamp for a raster map. |
| r3.info | Outputs basic information about a user-specified 3D raster map layer. |
| r3.support | Allows creation and/or modification of 3D raster map layer support files. |
| r3.timestamp | Modifies a timestamp for a 3D raster map. |
| t.info | Lists information about space time datasets and maps. |
| t.select | Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra. |
| t.support | Modifies the metadata of a space time dataset. |
| t.upgrade | Upgrades the version of the temporal database. |
| v.info | Outputs basic information about a vector map. |
| v.support | Updates vector map metadata. |
| v.timestamp | Modifies a timestamp for a vector map. |
See also the corresponding keyword metadata for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.0.3dev Reference Manual
