GRASS logo
GRASS GIS Database
Table of contents
A GRASS GIS Database is simply a set of directories and files with certain structure which GRASS GIS works efficiently with. Location is a directory with data related to one geographic location or a project. All data within one Location has the same cartographic projection. A Location contains Mapsets and each Mapset contains data related to a specific task, user or a smaller project. Within each Location, a mandatory PERMANENT Mapset exists which can contain commonly used data within a Location such as base maps. PERMANENT Mapset also contains metadata related to Location such as projection. When GRASS GIS is started it connects to a Database, Location and Mapset specified by the user.
example: nc_spm - highway - elevation
Fig. 1: GRASS GIS Database structure as visible to the user
GRASS GIS Database
All data for GRASS GIS must be in GRASS GIS Database which is a directory (visible on the disk) containing subdirectories which are GRASS Locations. User can have one or more of Databases on the disk. Typically users have one directory called grassdata in their home directory. In multi-user environment users often have a grassdata directory mounted as a network directory (network file system). For teams, a centralized GRASS DATABASE would be defined in a shared network file system (e.g. NFS).
GRASS GIS Databases can be safely copied or moved as any other directories. Don't be confused with (relational) databases which are used in GRASS GIS to hold attribute data and might be part of the GRASS GIS Database. From user point of view, GRASS GIS Database with all its data in it is similar to, e.g. PostGIS, database, as it stores all information inside in a specific format and is accessible by specific tools. GRASS GIS Databases is in GRASS GIS often called GISDBASE or DATABASE.
GRASS Locations
Location is a directory which contains GRASS Mapsets which are its subdirectories. All data in one Location have the same projection (coordinate system, datum). Each Location must contain Mapset called PERMANENT. Typically, a Location contains all data related to one project or a geographic area (geographic location or region). Alternatively, Location can simply contain all data in a given projection.
GRASS Locations can be safely copied or moved as any other directories. Compressed Location is usually what GRASS users exchange between each other when they want to share a lot of data. For example, GRASS GIS sample data are provided as Locations.
Don't be confused with location as a place (file or directory) in a file system. The word location in GRASS Location refers to a location or area on Earth (or whatever is applicable). Users and programmers familiar with relational databases such as PostgreSQL can view Location as an individual database inside the system or a storage area which would be equivalent to GRASS GIS Database. Mapsets in a Locations are like namespaces or schemas inside a database.
GRASS Mapsets
Mapsets contains the actual data, mostly geospatial data, referred to as maps in GRASS GIS. Mapsets are a tool for organizing maps in a transparent way as well as a tool for isolating different tasks to prevent data loss.
GRASS GIS is always connected to one particular Mapset. GRASS GIS modules can create, modify, change, or delete a data only in the current Mapset. By default, only the data from the current Mapset and PERMANENT Mapset are visible. Using g.mapsets module or in GUI other Mapsets can be made visible and seamlessly accessible. All data are available for reading when Mapset is specified explicitly, for example to access map streets in Mapset new_highway user can use streets@new_highway. For maps which are in the current or PERMAENT Mapsets or Mapsets sets as visible (accessible), there is no need to use @mapset syntax.
Mapsets are used to store maps related to one project, smaller project, specific task, issue or subregions. In multi-user environment, when a team works together on one project, Mapsets support simultaneous access of several users to the maps stored within the same Location. Besides access to his or her own Mapset, each user can also read maps in PERMANENT Mapsent and in other users' Mapsets when set. However, each user can modify or remove only the maps in his or her own Mapset.
Besides the geospatial data, Mapset holds additional data such as color tables (managed e.g. by r.colors) and the current computational region's extent and resolution stored in a file called WIND and managed by g.region.
Mapsets can be copied and moved as directories, however only when it is clear that the projections of both Locations (as reported by g.proj) match each other. Since this is sometimes hard to to establish, it is recommended to use r.proj or v.proj to reproject the data. The files and directories should not be moved or modified directly, but only using GRASS GIS tools.
The role of the PERMANENT Mapset
When creating a new Location, GRASS GIS automatically creates a special Mapset called PERMANENT where the core data for the Location are stored.
Since the maps in PERMANENT Mapset are visible from all the other Mapsets, it can be used to store the base maps (base cartography), data common to all projects or needed for different analyses done is separate Mapsets.
In multi-user environment, data in the PERMANENT Mapset can only be added, modified or removed by the owner of the PERMANENT Mapset; however, they can be accessed, analyzed, and copied into their own Mapset by the other users. The PERMANENT Mapset is useful for providing general spatial data (e.g. an elevation model), accessible but write-protected to all users who are working in the same Location as the database owner. To manipulate or add data to PERMANENT, the owner can start GRASS GIS and choose the relevant Location and the PERMANENT Mapset.
The PERMANENT Mapset also contains the DEFAULT_WIND file which holds the default computational region's extent and resolution values for the Location (which all Mapsets will inherit when they are created). Users have the option of switching back to the default region at any time.
Importing, exporting and linking data
GRASS GIS works only with data which are imported into a GRASS Database, so all data needs to be imported, e.g. by r.in.gdal or highly convenient r.import, before the actual analysis. Data in GRASS Datable can be exported using for example r.in.gdal in case of raster maps.
For cases when import is not desirable, an option to link external data exists. Projection of the linked data must match the Location's projection otherwise the external data cannot be linked. (Linking data in different projection is not allowed as it would require on-the-fly reprojection which could cause inconsistencies in the data.
For example, module r.external links external raster data, so that the data are accessible in GRASS Database as standard raster maps. Similarly for newly created maps, r.external.out setups a format and directory where the actual data will be stored, however in GRASS Database the data will be created as standard maps.
Starting GRASS GIS using GUI
After launching GRASS GIS, the startup window will open (Fig. 2).
startup window with numbered fields
Fig. 2: GRASS GIS startup window
The startup windows provides these functions:
  1. Selecting the GRASS GIS Database directory.
  2. Selecting the Location (e.g. a project or area). See the Location Wizard (4) for creating new Locations.
  3. Selecting the Mapset (a subproject or task). Creating a new Mapset requires only name.
  4. The Location Wizard for creating new Locations based for example, on existing georeferenced file or EPSG code.
  5. Download a sample Location from the Internet.
  6. Start GRASS GIS once you have selected an existing Location and Mapset or defined a new one. The graphical user interface wxGUI will open and provide you with a menu system, map visualization tool, digitizer, and more.
Starting GRASS GIS using command line
GRASS GIS can be started with given Database, Location and Mapset from the command line. For example, the following will start in a given Mapset with only command line interface:
# Linux, Mac, *BSD, ...:
grass --text ~/grassdata/nc_spm_08_grass7/user1
# Windows
grass --text D:\grassdata\nc_spm_08_grass7\user1
And the following will create the given Location with projection given by the EPSG code and it will start the default interface (GUI or command line):
grass -c EPSG:5514:3 ~/grassdata/mylocation
# Windows
grass -c EPSG:5514:3 D:\grassdata\mylocation
See grass command manual for more details.
Creating a New Location with the Location Wizard
The wxGUI graphical user interface provides a graphical Location Wizard which lets you easily create a new Location for your own data. You will be guided through a series of dialogues to browse and select predefined projections or to define custom projections.
The most convenient way of using Location Wizard is creating new Location based on a georeferenced file, such as Shapefile or GeoTIFF, or by selecting the corresponding EPSG projection code. In case of using georeferenced file, you are asked whether the data itself should be imported into the new Location. The default region is then set to match imported map.
After defining a new Location, wxGUI starts automatically. If data were already imported, you can add them into the Layer Manager now and display them. More data can be imported into the Location, e.g. using import options in the File menu in Layer Manager or r.import.
See also
GRASS GIS Reference Manual
GRASS GIS startup program manual page
Importing data on GRASS Wiki
r.import, v.import, r.external, v.external, r.proj, v.proj,
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.3.dev Reference Manual
