GRASS logo
NAME
r.mfilter - Performs raster map matrix filter.
KEYWORDS
raster, algebra, statistics, filter, parallel
SYNOPSIS
r.mfilter
r.mfilter --help
r.mfilter [-z] input=name output=name filter=name [repeat=integer] [title=string] [nprocs=integer] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-z
Apply filter only to null data values
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
input=name [required]
Name of input raster map
output=name [required]
Name for output raster map
filter=name [required]
Path to filter file
repeat=integer
Number of times to repeat the filter
Default: 1
title=string
Output raster map title
nprocs=integer
Default: 1
Table of contents
DESCRIPTION
r.mfilter filters the raster input to produce the raster output according to the matrix filter designed by the user (see FILTERS below). The filter is applied repeat times (default value is 1). The output raster map layer can be given a TITLE if desired. (This TITLE should be put in quotes if it contains more than one word.) With -z flag the filter is applied only to null values in the input raster map layer. The non-null category values are not changed. Note that if there is more than one filter step, this rule is applied to the intermediate raster map layer -- only null category values which result from the first filter will be changed. In most cases this will NOT be the desired result. Hence -z should be used only with single step filters.
The filter parameter defines the name of an existing, user-created UNIX ASCII file whose contents is a matrix defining the way in which the input file will be filtered. The format of this file is described below, under FILTERS.
The repeat parameter defines the number of times the filter is to be applied to the input data.
FILTERS
The filter file is a normal UNIX ASCII file designed by the user. It has the following format:
     TITLE      TITLE
     MATRIX     n
     n lines of n values
     DIVISOR    d
     TYPE        S/P
TITLE
A one-line TITLE for the filter. If a TITLE was not specified on the command line, it can be specified here. This TITLE would be used to construct a TITLE for the resulting raster map layer. It should be a one-line description of the filter.
MATRIX
The matrix (n x n) follows on the next n lines. n must be an odd integer greater than or equal to 3. The matrix itself consists of n rows of n values. The values must be separated from each other by at least 1 blank.
DIVISOR
The filter divisor is d. If not specified, the default is 1. If the divisor is zero (0), then the divisor is dependent on the category values in the neighborhood (see HOW THE FILTER WORKS below).
TYPE
The filter type. S means sequential, while P mean parallel. If not specified, the default is S.
Sequential filtering happens in place. As the filter is applied to the raster map layer, the category values that were changed in neighboring cells affect the resulting category value of the current cell being filtered.
Parallel filtering happens in such a way that the original raster map layer category values are used to produce the new category value.
More than one filter may be specified in the filter file. The additional filter(s) are described just like the first. For example, the following describes two filters:
EXAMPLE FILTER FILE
      TITLE     3x3 average, non-null data only, followed by 5x5 average
     MATRIX    3
     1 1 1
     1 1 1
     1 1 1
     DIVISOR   0
     TYPE      P
     MATRIX    5
     1 1 1 1 1
     1 1 1 1 1
     1 1 1 1 1
     1 1 1 1 1
     1 1 1 1 1
     DIVISOR   25
     TYPE      P
The filter process produces a new category value for each cell in the input raster map layer by multiplying the category values of the cells in the n x n neighborhood around the center cell by the corresponding matrix value and adding them together. If a divisor is specified, the sum is divided by this divisor. (If a zero divisor was specified, then the divisor is computed for each cell as the sum of the MATRIX values where the corresponding input cell is non-null.)
If more than one filter step is specified, either because the repeat value was greater than one or because the filter file contained more than one matrix, these steps are performed sequentially. This means that first one filter is applied to the entire input raster map layer to produce an intermediate result; then the next filter is applied to the intermediate result to produce another intermediate result; and so on, until the final filter is applied. Then the output cell is written.
PERFORMANCE
By specifying the number of parallel processes with nprocs option, r.mfilter can run significantly faster, see benchmarks below.
benchmark for number of cells benchmark for window size
Figure: Benchmark on the left shows execution time for different number of cells for 9x9 matrix, benchmark on the right shows execution time for 16 billion cells for different matrix sizes. (Intel Core i9-10940X CPU @ 3.30GHz x 28)
Note that parallelization is implemented only for the parallel filter, not the sequential one. To take advantage of the parallelization, GRASS GIS needs to compiled with OpenMP enabled.
NOTES
If the resolution of the geographic region does not agree with the resolution of the raster map layer, unintended resampling of the original data may occur. The user should be sure that the geographic region is set properly.
SEE ALSO
g.region, r.clump, r.neighbors, r.resamp.filter,
Raster Parallelization with OpenMP
AUTHORS
Glynn Clements. Based upon r.mfilter, by Michael Shapiro, U.S.Army Construction Engineering Research Laboratory.
Aaron Saw Min Sern (OpenMP support).
SOURCE CODE
Available at: r.mfilter source code (history)
Latest change: Thursday Feb 03 11:10:06 2022 in commit: 547ff44e6aecfb4c9cbf6a4717fc14e521bec0be
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.3.dev Reference Manual
