GRASS logomenu
Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
NAME
r.mess - Computes multivariate environmental similarity surface (MES)
KEYWORDS
similarity, raster, modelling
SYNOPSIS
r.mess
r.mess --help
r.mess [-mnkci] env=names[,names,...] [env_proj=names[,names,...]] [ref_rast=name] [ref_vect=name] output=name [digits=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-m
Calculate Most dissimilar variable (MoD)
-n
Area with negative MESS
-k
sum(IES), where IES < 0
-c
Number of IES layers with values < 0
-i
Remove individual environmental similarity layers (IES)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
env=names[,names,...] [required]
Reference conditions
Projected conditions
ref_rast=name
Reference area (raster)
Reference areas (1 = presence, 0 or null = absence)
ref_vect=name
Reference points (vector)
Point vector layer with presence locations
output=name [required]
Root name of the output MESS data layers
digits=string
Precision of your input layers values
Default: 3
Table of contents
DESCRIPTION
The Multivariate Environmental Similarity (MES) surfaces was proposed by Elith et al (2010) [1] and originally implemented in the Maxent software. The MES provides a measure of the proportional distance of any points (in the projection data) with respect to the range of individual covariates from the reference data. More precisely, the MES represents how similar a point is to a reference set of points, with respect to a set of predictor variables (V1, V2, ...). The values in the MESS are influenced by the full distribution of the reference points. So, sites within the environmental range of the reference points but in relatively unusual environments will have a smaller value than those in very common environments. See the supplementary materials of Elith et al. (2010) [1] for more details.
r.mess computes the MES and the individual similarity layers (IES - the user can select to delete these layers) and, optionally, several other layers that help to further interpret the MES values.
The user can compare a set of reference / baseline conditions (ref) and projected / test conditions (proj). For the reference conditions, the whole region can be used (no reference areas or points are given). Alternatively, one can define a set of reference/sample points (presvect) or reference/sample areas (presrast) against which other areas are to be compared. The projected conditions can be future conditions in the same area (similarity across time), or conditions in another area (similarity between two different areas). See the examples for more details.
NOTES
Note that a mask is taken into account when computing the frequency distribution of the reference data layers, but is removed when computing the output layers. This means that instead of using a raster layer to delimit an reference / sample area (ref_rast, see example 2), one can use the mask to delimit a reference area, and compute how similar the areas area outside the mask.
EXAMPLE
The examples below use the bioclimatic variables bio1 (mean annual temperature), bio12 (annual precipitation), and bio15 (precipitation seasonality) in Kenya and Uganda. All climate layers (current and future) are from Worldclim.org. The protected areas layer includes all nationally designated protected areas with a IUCN category of II or higher from protectedplanet.net.
Example 1
The simplest case is when only a set of reference data layers (env ) is provided. The multi-variate similarity values of the resulting map are a measure of how similar conditions in a location are to the median conditions in the whole region.
g.region raster=bio1
r.mess env=bio1,bio12,bio15 output=Ex_01
Thus, in the maps above, the value in each pixel represents how similar conditions are in that pixel to the median conditions in the entire region, in terms of mean annual temperature (bio1), mean annual precipitation (bio12), precipitation seasonality (bio15) and the three combined (MES).
Example 2
In the second example, conditions in the entire region are compared to those in the region's protected areas (ppa), which thus serves as the reference/sample area. See van Breugel et al.(2015) [3] for an example of how this can be useful.
r.mess -m -n -i env=bio1,bio12,bio15 ref_rast=ppa output=Ex_02
In the figure below the map with the protected areas, the MES, the most dissimilar variables, and the areas with novel conditions are given. They show that the protected areas cover most of the region's annual precipitation, mean annual temperature, and precipitation seasonality gradients. Areas with novel conditions can be found in northern Kenya.
Example 3
Similarity between long-term average conditions based on the period 1950-2000 (env) and projections for climate conditions in 2070 under RCP85 based on the IPSL General Circulation Models ( env_proj). No reference points or areas are defined in this example, so the whole region is used as a reference. Note that this is equivalent to what the Maxent program does when computing the MESS layers.
r.mess env=bio1,bio12,bio15 env_proj=IPSL_bio1,IPSL_bio12,IPSL_bio15
output=Ex_03
Results (below) shows that there is a fairly large area with novel conditions. Note that in the MES map, the values are based on the highest negative value across the input variables (here bio1, bio12, bio15). In the SumNeg map, values of all input variables are summed when negative. The Count map shows for each raster cell how many variables have negative similarity scores. Thus, the values in the MES and SumNeg maps only differ where the MES of more than one variable is negative (dark gray areas in the Count map).
REFERENCES
[1] Elith, J., Kearney, M., & Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.
[2] Mesgaran, M.B., Cousens, R.D. & Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
[3] van Breugel, P., Kindt, R., Lillesø, J.-P.B., & van Breugel, M. 2015. Environmental Gap Analysis to Prioritize Conservation Efforts in Eastern Africa. PLoS ONE 10: e0121444.
AUTHOR
Paulo van Breugel, paulo at ecodiv.earth
SOURCE CODE
Available at: r.mess source code (history)
Latest change: Monday Jun 24 08:16:48 2024 in commit: 8939a985d18de5366340b88037ab0fe3a0814c9b
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
