Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
db.columns List all columns for a given table.
db.connect Prints/sets general DB connection for current mapset.
db.copy Copy a table.
db.createdb Creates an empty database.
db.databases Lists all databases for a given driver and location.
db.describe Describes a table in detail.
db.drivers Lists all database drivers.
db.dropcolumn Drops a column from selected attribute table.
db.dropdb Removes an existing database.
db.droptable Drops an attribute table.
db.execute Executes any SQL statement.
db.in.ogr Imports attribute tables in various formats.
db.login Sets user/password for DB driver/database.
db.out.ogr Exports attribute tables into various formats.
db.select Selects data from attribute table.
db.tables Lists all tables for a given database.
db.test Test database driver, database must exist and set by db.connect.
db.univar Calculates univariate statistics on selected table column.Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
