Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
The result is a new space time vector dataset that contains a single (new) vector map which links to as many time-stamped attribute tables as raster map layers are present in the input space time raster dataset. Hence, for each time step in the space time raster dataset a new attribute table is created. The GRASS GIS Temporal Framework allows to time stamp attribute tables that can be linked to a single vector map layer.
The module v.what.rast is used internally for sampling the time stamped raster map layers. All sampled values of a single time stamped raster map layer are written into a new time stamped attribute table.
Use t.vect.db.select to print attribute values of the space time vector dataset to stdout.
t.vect.observe.strds input=precip_30ynormals_3d strds=tempmean_monthly \
output=precip_stations vect=precip_stations_monthly \
columns=month
t.info precip_stations type=stvds
+-------------------- Space Time Vector Dataset -----------------------------+
+-------------------- Basic information -------------------------------------+
| Id: ........................ precip_stations@climate_2009_2012
| Name: ...................... precip_stations
| Mapset: .................... climate_2009_2012
| Creator: ................... lucadelu
| Temporal type: ............. absolute
| Creation time: ............. 2014-12-02 00:42:39.187615
| Modification time:.......... 2014-12-02 00:42:55.215169
| Semantic type:.............. mean
+-------------------- Absolute time -----------------------------------------+
| Start time:................. 2009-01-01 00:00:00
| End time:................... 2013-01-01 00:00:00
| Granularity:................ 1 month
| Temporal type of maps:...... interval
+-------------------- Spatial extent ----------------------------------------+
| North:...................... 306221.830194
| South:...................... 27606.895351
| East:.. .................... 917004.829165
| West:....................... 151768.568246
| Top:........................ 1615.44
| Bottom:..................... 2.4384
+-------------------- Metadata information ----------------------------------+
| Vector register table:...... vector_map_register_be074525097c4088997c9a1979f17065
| Number of points ........... 6664
| Number of lines ............ 0
| Number of boundaries ....... 0
| Number of centroids ........ 0
| Number of faces ............ 0
| Number of kernels .......... 0
| Number of primitives ....... 6664
| Number of nodes ............ 0
| Number of areas ............ 0
| Number of islands .......... 0
| Number of holes ............ 0
| Number of volumes .......... 0
| Number of registered maps:.. 49
| Title:
| Observaion of space time raster dataset(s) tempmean_monthly
| Description:
| Observation of space time raster dataset(s) tempmean_monthly with vector map precip_30ynormals_3d
| Command history:
| # 2014-12-02 00:42:39
| t.vect.observe.strds input="precip_30ynormals_3d"
| strds="tempmean_monthly" output="precip_stations"
| vect="precip_stations_monthly" columns="month"
v.info precip_stations_monthly
| Mapset: climate_2009_2012 |
| Database: /grassdata |
| Title: North Carolina 30 year precipitation normals (3D) |
| Map scale: 1:1 |
| Name of creator: neteler |
| Organization: |
| Source date: Wed May 9 14:32:39 2007 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 136 Number of centroids: 0 |
| Number of lines: 0 Number of boundaries: 0 |
| Number of areas: 0 Number of islands: 0 |
| Number of faces: 0 Number of kernels: 0 |
| Number of volumes: 0 Number of holes: 0 |
| Map is 3D: Yes |
| Number of dblinks: 49 |
| Projection: Lambert Conformal Conic |
| N: 306221.830194 S: 27606.895351 |
| E: 917004.829165 W: 151768.568246 |
| B: 2.4384 T: 1615.44 |
| Digitization threshold: 0 |
| Comment: |
Available at: t.vect.observe.strds source code (history)
Latest change: Thursday Feb 03 11:10:06 2022 in commit: 547ff44e6aecfb4c9cbf6a4717fc14e521bec0be
Main index | Temporal index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
