Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
| db.columns | List all columns for a given table. |
| db.connect | Prints/sets general DB connection for current mapset. |
| db.copy | Copy a table. |
| db.createdb | Creates an empty database. |
| db.databases | Lists all databases for a given driver and location. |
| db.describe | Describes a table in detail. |
| db.dropcolumn | Drops a column from selected attribute table. |
| db.dropdb | Removes an existing database. |
| db.droptable | Drops an attribute table. |
| db.execute | Executes any SQL statement. |
| db.select | Selects data from attribute table. |
| db.tables | Lists all tables for a given database. |
| db.test | Test database driver, database must exist and set by db.connect. |
| t.vect.db.select | Prints attributes of vector maps registered in a space time vector dataset. |
| v.db.addcolumn | Adds one or more columns to the attribute table connected to a given vector map. |
| v.db.addtable | Creates and connects a new attribute table to a given layer of an existing vector map. |
| v.db.connect | Prints/sets DB connection for a vector map to attribute table. |
| v.db.dropcolumn | Drops a column from the attribute table connected to a given vector map. |
| v.db.droprow | Removes a vector feature from a vector map through attribute selection. |
| v.db.droptable | Removes existing attribute table of a vector map. |
| v.db.join | Joins a database table to a vector map table. |
| v.db.reconnect.all | Reconnects attribute tables for all vector maps from the current mapset to a new database. |
| v.db.renamecolumn | Renames a column in the attribute table connected to a given vector map. |
| v.db.select | Prints vector map attributes. |
| v.db.update | Updates a column in the attribute table connected to a vector map. |
| v.to.db | Populates attribute values from vector features. |
| v.vect.stats | Count points in areas, calculate statistics from point attributes. |
See also the corresponding keyword attribute table for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
