Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
r.resamp.filter | Resamples raster map layers using an analytic kernel. |
r.resamp.interp | Resamples raster map to a finer grid using interpolation. |
r.resamp.rst | Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing. |
r.resamp.stats | Resamples raster map layers to a coarser grid using aggregation. |
r.resample | GRASS raster map layer data resampling capability. |
See also the corresponding keyword resample for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
