Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
| r.contour | Produces a vector map of specified contours from a raster map. |
| r.fill.stats | Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated values (IDW). |
| r.fillnulls | Fills no-data areas in raster maps using spline interpolation. |
| r.random.surface | Generates random surface(s) with spatial dependence. |
| r.resamp.bspline | Performs bilinear or bicubic spline interpolation with Tykhonov regularization. |
| r.surf.area | Prints estimation of surface area for raster map. |
| r.surf.contour | Generates surface raster map from rasterized contours. |
| r.surf.fractal | Creates a fractal surface of a given fractal dimension. |
| r.surf.gauss | Generates a raster map using gaussian random number generator. |
| r.surf.idw | Provides surface interpolation from raster point data by Inverse Distance Squared Weighting. |
| r.surf.random | Produces a raster surface map of uniform random deviates with defined range. |
| v.surf.bspline | Performs bicubic or bilinear spline interpolation with Tykhonov regularization. |
| v.surf.idw | Provides surface interpolation from vector point data by Inverse Distance Squared Weighting. |
| v.surf.rst | Performs surface interpolation from vector points map by splines. |
See also the corresponding keyword surface for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 8.2.2dev Reference Manual
