GRASS logo
Topic: export
d.out.file Saves the contents of the active display monitor to a graphics file.
d.to.rast Saves the contents of the active display monitor to a raster map.
db.out.ogr Exports attribute tables into various formats.
r.external.out Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format.
r.out.ascii Converts a raster map layer into a GRASS ASCII text file.
r.out.bin Exports a GRASS raster to a binary array.
r.out.gdal Exports GRASS raster maps into GDAL supported formats.
r.out.gridatb Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL).
r.out.mat Exports a GRASS raster to a binary MAT-File.
r.out.mpeg Converts raster map series to MPEG movie.
r.out.png Export a GRASS raster map as a non-georeferenced PNG image.
r.out.pov Converts a raster map layer into a height-field file for POV-Ray.
r.out.ppm Converts a GRASS raster map to a PPM image file.
r.out.ppm3 Converts 3 GRASS raster layers (R,G,B) to a PPM image file.
r.out.vrml Exports a raster map to the Virtual Reality Modeling Language (VRML).
r.out.vtk Converts raster maps into the VTK-ASCII format.
r.out.xyz Exports a raster map to a text file as x,y,z values based on cell centers.
r.pack Exports a raster map as GRASS GIS specific archive file
r3.out.ascii Converts a 3D raster map layer into a ASCII text file.
r3.out.bin Exports a GRASS 3D raster map to a binary array.
r3.out.netcdf Export a 3D raster map as netCDF file.
r3.out.v5d Exports GRASS 3D raster map to 3-dimensional Vis5D file.
r3.out.vtk Converts 3D raster maps into the VTK-ASCII format.
t.rast.export Exports space time raster dataset.
t.rast.out.vtk Exports space time raster dataset as VTK time series.
t.vect.export Exports a space time vector dataset as GRASS GIS specific archive file.
v.external.out Defines vector output format.
v.out.ascii Exports a vector map to a GRASS ASCII vector representation.
v.out.dxf Exports vector map to DXF file format.
v.out.ogr Exports a vector map layer to any of the supported OGR vector formats.
v.out.postgis Exports a vector map layer to PostGIS feature table.
v.out.pov Converts GRASS x,y,z points to POV-Ray x,z,y format.
v.out.svg Exports a vector map to SVG file.
v.out.vtk Converts a vector map to VTK ASCII output.
v.pack Exports a vector map as GRASS GIS specific archive file
See also the corresponding keyword export for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2024 GRASS Development Team, GRASS GIS 8.3.3dev Reference Manual
