GRASS logo
NAME
r.mess - Computes multivariate environmental similarity surface (MES)
KEYWORDS
similarity, raster, modelling
SYNOPSIS
r.mess
r.mess --help
r.mess [-mnkci] ref_env=names[,names,...] [ref_rast=name] [ref_vect=name] [ref_region=name] [proj_env=names[,names,...]] [proj_region=name] output=name [digits=string] [nprocs=integer] [memory=memory in MB] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-m
Calculate Most dissimilar variable (MoD)
-n
Area with negative MESS
-k
sum(IES), where IES < 0
-c
Number of IES layers with values < 0
-i
Remove individual environmental similarity layers (IES)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
ref_env=names[,names,...] [required]
Reference conditions
ref_rast=name
Reference area (raster)
Reference areas (1 = presence, 0 or null = absence)
ref_vect=name
Reference points (vector)
Point vector layer with reference locations
ref_region=name
Reference region
Region with reference conditions
Projected conditions
proj_region=name
Projection region
Region with projected conditions
output=name [required]
Root name of the output MESS data layers
digits=string
Precision of your input layers values
Options: 0-6
Default: 3
nprocs=integer
Default: 1
memory=memory in MB
Maximum memory to be used (in MB)
Cache size for raster rows
Default: 300
Table of contents
DESCRIPTION
r.mess computes the multivariate environmental similarity (MES) [1], which measures how similar environmental conditions in one area are to those in a reference area. This can also be used to compare environmental conditions between current and future scenarios. See the supplementary materials of Elith et al. (2010) [1] for more details.
Besides the MES, r.mess computes the individual similarity layers (IES - the user can select to delete these layers) and, optionally, several other layers that help to further interpret the MES values:
The user can compare a set of reference (baseline) conditions to projected (test) conditions. The reference conditions are defined by a set of environmental raster layers (ref_env). To specify the reference area, one of the following can be used:
If no reference raster map, vector map, or region is provided, the entire area covered by the input environmental raster layers is used as the reference area.
The projected (test) conditions are defined by a second set of environmental variables (proj_env). They can represent future conditions in the same area (similarity across time), or conditions in another area (similarity between two different areas). If a projection region (proj_region) is provided, the MESS (and other layers) will be limited to that region.
If proj_env is not provided, the MESS value of a raster cell represents how similar the conditions in that cell are compared to the medium conditions across the whole area.
EXAMPLE
The examples below use the bioclimatic variables bio1 (mean annual temperature), bio12 (annual precipitation), and bio15 (precipitation seasonality) in Kenya and Uganda. All climate layers (current and future) are from Worldclim.org. The protected areas layer includes all nationally designated protected areas with a IUCN category of II or higher from protectedplanet.net.
Example 1
The simplest case is when only a set of reference data layers (ref_env ) is provided. The multi-variate similarity values of the resulting map are a measure of how similar conditions in a location are to the median conditions in the whole region.
g.region raster=bio1
r.mess ref_env=bio1,bio12,bio15 output=Ex_01
Thus, in the following maps, the value in each pixel represents how similar conditions are in that pixel to the median conditions in the entire region, in terms of mean annual temperature (bio1), mean annual precipitation (bio12), precipitation seasonality (bio15) and the three combined (MES).
Example 2
In the second example, conditions in the whole region are compared to those in the region's protected areas (ppa), which thus serves as the reference/sample area. See van Breugel et al.(2015) [3] for an example of how this can be useful.
r.mess -m -n -i ref_env=bio1,bio12,bio15 ref_rast=ppa output=Ex_02
In the figure below the map with the protected areas, the MES, the most dissimilar variables, and the areas with novel conditions are given. They show that the protected areas cover most of the region's annual precipitation, mean annual temperature, and precipitation seasonality gradients. Areas with novel conditions can be found in northern Kenya.
Example 3
Similarity between long-term average conditions based on the period 1950-2000 (ref_env) and projections for climate conditions in 2070 under RCP85 based on the IPSL General Circulation Models ( proj_env). No reference points or areas are defined in this example, so the whole region is used as a reference.
r.mess ref_env=bio1,bio12,bio15 proj_env=IPSL_bio1,IPSL_bio12,IPSL_bio15
output=Ex_03
Results (below) shows that there is a fairly large area with novel conditions. Note that in the MES map, the values are based on the highest negative value across the input variables (here bio1, bio12, bio15). In the SumNeg map, values of all input variables are summed when negative. The Count map shows for each raster cell how many variables have negative similarity scores. Thus, the values in the MES and SumNeg maps only differ where the MES of more than one variable is negative (dark gray areas in the Count map).
REFERENCES
[1] Elith, J., Kearney, M., & Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.
[2] Mesgaran, M.B., Cousens, R.D. & Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
[3] van Breugel, P., Kindt, R., Lillesø, J.-P.B., & van Breugel, M. 2015. Environmental Gap Analysis to Prioritize Conservation Efforts in Eastern Africa. PLoS ONE 10: e0121444.
SEE ALSO
For an example of using the r.mess addon as part of a modeling workflow, see the tutorial Species distribution modeling using Maxent in GRASS GIS.
AUTHOR
Paulo van Breugel, https://ecodiv.earth | HAS green academy University of Applied Sciences | Innovative Biomonitoring research group | Climate-robust Landscapes research group
SOURCE CODE
Available at: r.mess source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit: 2a14bbb9928039c7c7d0ac539d42b08ff72c88f7
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.3dev Reference Manual
