| r.basins.fill | Generates watershed subbasins raster map. |
| r.carve | Generates stream channels. |
| r.drain | Traces a flow through an elevation model or cost surface on a raster map. |
| r.fill.dir | Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map. |
| r.flow | Constructs flowlines. |
| r.lake | Fills lake at given point to given level. |
| r.path | Traces paths from starting points following input directions. |
| r.sim.sediment | Sediment transport and erosion/deposition simulation using path sampling method (SIMWE). |
| r.sim.water | Overland flow hydrologic simulation using path sampling method (SIMWE). |
| r.solute.transport | Numerical calculation program for transient, confined and unconfined solute transport in two dimensions |
| r.stream.extract | Performs stream network extraction. |
| r.terraflow | Performs flow computation for massive grids. |
| r.topidx | Creates a topographic index (wetness index) raster map from an elevation raster map. |
| r.topmodel | Simulates TOPMODEL which is a physically based hydrologic model. |
| r.uslek | Computes USLE Soil Erodibility Factor (K). |
| r.usler | Computes USLE R factor, Rainfall erosivity index. |
| r.water.outlet | Creates watershed basins from a drainage direction map. |
| r.watershed | Calculates hydrological parameters and RUSLE factors. |
| r3.flow | Computes 3D flow lines and 3D flow accumulation. |
See also the corresponding keyword hydrology for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.3dev Reference Manual
