Topic: segmentation
| Tool | Description |
| i.segment | Identifies segments (objects) from imagery data. |
See also the corresponding keyword for additional references:
segmentation
- i.sam2 - Integrates SAMGeo model with text prompt for segmentation in GRASS GIS.
- i.segment - Identifies segments (objects) from imagery data.
- i.segment.gsoc - Outputs a single segmented map (raster) based on input values in an image group.
- i.segment.stats - Calculates statistics describing raster areas.
- i.segment.uspo - Unsupervised segmentation parameter optimization
- i.smap - Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation.
- i.superpixels.slic - Perform image segmentation using the SLIC segmentation method.
- r.smooth.seg - Generates a piece-wise smooth approximation of the input raster and a discontinuity map.
